Adie Roberts gets his hands on the Meng Model 3rd offering of the Kuberlwagen to see the difference between it and the first two and see what this one is all about
I should probably add it is a pretty easy build; the parts all fit well and since there is no engine detail or anything under the trunk that simplifies it a bit further. The interior is pretty basic although you definitely could add personal effects and gear for the crew inside.
That said, because the way this kit is set up you can only make this vehicle. In fact, all the Meng Vee Dubs are what the box portrays with no extras, so if you want to make a diorama you’re better off with any of the Dragon kits or even the old Tamiya rather than these. Meng doesn’t even let you choose top down or up.
