HEMTT Engine Replacement
Hello All,
Just started prebuilding a THADD from trumpeter and the biggest disappointments in all of the HEMTT kits is the terrible engines that are provided so any suggestions on a replacement of did one of you CAD wizards come up with one already and I missed it.
I did not help Miroslav with this one, but it’s still a good set.
I saw this one and weas kind of shocked that it was the only option, Also is there an option for the A4.
They’re both C15 engines, albeit with different HP ratings. I’d use it.
I second the Real Model HEMTT engine. It comes out very nicely.
IMG_1042_zpsr4qmwwjz
IMG_1039_zpsxo0ltych
IMG_1040_zpsidd35o86
IMG_1041_zpss9omfdpo
IMG_1059_zpspgriknau
IMG_1069_zpsiixabjbw
With a little work, adding bits here and there, and a few wires, the Trumpeter engine can look passable as well. If you leave it closed up, you can;t see much of it anyways.
IMG_1964
IMG_1963
Is there a replacement engine for the newer trucks that now are running the CAT engine (I think C17 or C18)
If you have or have access to a 3D printer there is.
3D HEMTT A4 Conversion Parts in the Works - Armor/AFV / Modern - KitMaker Network
