Well Rob, funny you’d mention those 1/32 trucks:
I built several of them. The red one above was the last in the series, so by this time I had a lot of it worked out. I wisely used
all K+B alu tube for the roll cages
…not the best idea - evergreen works a lot better. Yes, the tires and wheels are supposed to be used on an LAV or a Stryker! perfect…they actually scale out reasonably closer to a 37/38" tire. As for the planetary hubs, well, you need to live with some things.
A few even got the old CMK HMMWV engine - well…it’s a V8 and I really wanted an engine in these. It would have been a lot easier if there was a 1/32 or 1/35 Chevy engine. Another challenge with these is that the beds and cabs are usually one piece, and the bed floors are really thick, requiring a lot of carving to get them make into a relatively detailed build.
Yes, I searched high and low for Chevy truck models at this scale
I didn’t keep much of the original kits, just the body, and I cut those up quite a bit too. The red and black step side was a very poorly cast resin slot car body, that took a LOT of work make decent, but worth it, as I really like stepsides
I used a 1/35 M1078 for my pull truck - added a 5th wheel etc.
At the time I was a better dio builder, than model builder, but with time and mistakes, a guy gets better at it.
I’d still like to see a 1/35 square body -
This is the old Miniman resin kit, which was pretty expensive. A nice overall kit, but as I recall, it didn’t have too many parts.
My guess is like the Meng F350 and Toyotas, other 1/35 vehicles might find a place in model builder’s stashes. I built a couple of the 1/24 F350 - which is a BIG and solid model - the Toyotas were/are really nice - high quality and go together really well.
So, for now, I’ll keep some hope for more 1/35 modern vehicles, including more square bodies!
Nick
