I often see these ammo boxes attached to the back of the bustle rack on the Abrams, but can never figure out how it is actually secured? Is it drilled and fixed with nuts and bolts?
Exactly.
Perfect, thank you!
Yup. Good old fashioned U Bolts.
Great attention to detail.
I thought it was real when it popped up on my phone.
IKR? Those track shoes look so realistic; it’s amazing level of detail.
Is this 1/35 or 1/16?
Thanks, apparently not enough attention to detail, just noticed the cracked connector link, gosh I hate small printed parts, too fragile. Going to put some CA glue in the crack and hide it with some paint/weathering.
That’s probably the best Abrams I’ve ever seen.
Very realistic!
I’ve wondered about this too! I’d imagine the mounting method depends on the specific ammo box and bustle rack configuration. Some mounts may use dedicated brackets or existing attachment points rather than drilling directly into the rack. It would be interesting to see a close-up of the mounting hardware from the inside to understand how it’s secured and how the weight is distributed.
No modification of the bustle rack at all, holes are drilled in the side of the ammo box that the arms of the u bolt pass through.
Nice. And maybe some washers. I never looked inside, but that’s what I’d do.
Plus, upcoming bike build will have battery and oil bag hidden in two of them underneath false bottoms. The vibration almost dictates them
I would use a single metal plate (piece of flat bar) instead of two washers.
Depends on the thickness of the sheet metal in the ammo-box …
Yes, my drawing is definitely not to scale.
I have actually done this and both ways are acceptable it really just depends on what you have on hand and how fast it needs to be installed.
