Hello Gents, could you give me a tip to white wash this vehicle from “ The battle of the bulge. 44”.
Many thanks for your kind help and suggestions.
Bernie
Bernie
I would spray OD as normal, spray hairspray then spray a thinned white layer. Remove the white paint with water as desired.
HTH
Thank you very much for your interesting suggestion.
Bernie
I’ve had good luck with AK washable white too.
Base as above and then hand paint overtop and remove as desired.
Many thanks, Canmedic.
