Definitely worthwhile putting fuselage together and wings with masking tape and checking the fit.
Also, be hyper careful of the gun sight in cockpit when handing…don’t ask me how I know that ![]()
So eventually, after feeling under the weather and not having the mojo… I managed to get the fuselage and wings looking ok, albeit after a lot of filling, sanding, filling, sanding and more very fine sanding to blend it all in…also filled areas around the gun ports, and the holes where the arrestor hook mounts.
The tailplane and rear stabilisers went on fine with no filling required.
Have made a basic template for lining up the exhaust deflector plates that were fitted on most (I think) night fighter versions to protect the pilots night vision from exhaust glare.
Above the plate is a smaller mounting strip which looks like it’s riveted in place which will also be added.
The main fuselage and wings are now assembled, along with the masked canopy.
Propellor assembly and wheels plus undercarriages are painted and ready to add once the whole fuselage is painted.
Yeap…I ran out of the batch I mixed ![]()
This coat is Tamiya rubber black. I will be masking other smaller areas and panels and then using NATO black and flat black to add a bit of tone to give it a better look.
Nice job on the wing root joint. What are you planning for the paint scheme?
Cajun ![]()
Thanks Terry, appreciated. The wing joins were the biggest issue and took a fair bit of work to get both sides to a reasonable state.
This will be the colour scheme … The night fighter version.
The Sqn markings will be different and the nose will all be black.
