And can’t find any on most webshops by any producers. I even tried Aliexpress. Does anyone have a tip where I could find any, or how to make some the easiest way? Thank you.
What about Thachwave 1/72 Generic Cargo Net ( TW203 ) ?
1/72 square cargo net as seen in various settings throughout the 20th century.
The 1/35th scale version looks like this
Website : https://thachweave.tripod.com/products.htm
If you don’t mind something a bit more DIY, you could use tulle (aka bridal veil material) available at cloth by the yard (meter) shops. One square yard/meter for a few bucks will give you enough material for literally hundreds of netting. You might also find some online in smaller quantities. Example of tulle used as camo netting in 1/72:
It’s the netting hanging over the gun barrel. In scale, I would say the mesh is about 6" - 8". Maybe a slightly better shot:
At one time, ‘The Scenic Factory’ carried this Netting (NY-01) Dark Yellow/Sand: $6.95 US back in 2014. I believe it came in green as well. They’ve since moved operations over to FB, so I’m out of that loop. HTH.
—mike
@justsendit: Looks like cheesecloth dyed dark yellow. Probably cheaper to make it yourself…
@spongya77: Are you looking for WWII era cargo netting or modern cargo netting?
That’s exactly what it is, but I didn’t know the scale size of cheesecloth back in 2014. … And besides, if I make everything, who’s going to support the modeling industry?
—mike
In 1/72, your best bet is probably bridal veil tulle. It comes in a few different shapes for the openings too and they can get pretty small.
I like tulle. I’ve recommended it many times, usually for use as a metal mesh. I think it’s a little stiff for netting though. I might suggest medical gauze. I have used that as well, and you can adjust the scale (sort of) by stretchi8ng it out. Just make sure you get the cotton kind and not the elastic kind.
I agree tulle is a bit stiff for use in smaller scales, but you could try dipping in boiling water for a few seconds, then shape it before it cools (don’t burn your fingers !).
