Hi,
I can’t create a new topic in Armorama. I follow all the steps as usual, and without any problems. However, when I click on “Create,” the system seems to process it, but immediately tells me that an error has occurred and it can’t do it.
When I try again, I can’t do it anymore, because it tells me there’s a post with that name…
Is it created and I can’t see it, or isn’t it created and I can’t do it anymore…?
Best regards and thanks in advance.
Whats the post title ?
Hi, ffirst I tried
AKATSIYA (ACACIA TREE) 2S3 LATE SPG 152MM, TRUMPETER 1/35 FLORAL BOOM!
Try a much simpler title… “Trumpeter Akatsiya 2S3 Late” should be safer.
Create it with just a simple text and image and save as draft to check, if ok then you can add the rest
Hola varanusk,
I tried what you mentioned, and now it appears successful. Although I created it as a draft, I imagine the administrator in charge will have to validate it first before it’s visible to users.
Thank you very much, and best regards. ![]()
Correct, it’s online now.
Oddly, the other 3 tries were there as well… seems that despite the error message, they were saved anyway.
I understand all of them except the most recent can be removed now, right?
Hi,
of course, And it’s also the right thing to do. I wouldn’t want to be taking up space with something redundant that no longer serves its purpose. If it’s possible to delete it, I’d be very grateful.
Navigating the forum is a bit complicated for me.
The truth is, I waited a day or a day and a half before trying again, as I know it takes a while to validate posts. But since I kept getting errors and thinking it was too long for validation, I decided to try again before bothering them and asking for help.
Thank you very much for everything, and best regards. ![]()
House cleaned ![]()
Thanks for sharing your work here, looking forward to seeing more of your work!
