Anti slip surface is done, time to finish all details on the upper deck.
One thing I was really mad at the end of the day, was the number plate… All Puma have a 7 as first letter, not an 8.
Antislip looks cool
Rabbits
Exactly. It is much to scale than mine. However there should not be antislip stuff under the pivoting handles of the various bins.
Olivier
Thank You, I’m a rivet counter, but I didn’t note this
Thank You, I checked my references and there are a lot of options Some bins covers are without anti slip, on the some the anti slip is worn out and on the some anti slip is visible even under pivoting handles And these handles are look like it can be raised during rotating.
Yeah, I noticed it, after checking references befor applying decals… And it killed my day.
Have fun building
Rabbits
It’s often the case with IDF armor. I had some hard time myself trying to figure out where the antislip was applied. Depending on the time frame it would be different.
Olivier
Impressive build. Inspiring! Very well done
