IJN Kagero 1/350
…and besides that, great work Tim! Torpedo launchers look absolutely stunning!
Jan
Thanks Jan!
The kit 12.7cm gunhouses, like the torpedo launchers, are pretty good right out of the box; I especially like the sculpted canvas blast bags. Tamiya even provided a full set of alternate barrels/bags so you can show the guns at high elevation. Nice!
The one area where these assemblies fall down is the surprisingly crude rear doors…
…but the Infini set includes one-piece brass replacements which fix things right up!
Another small change was to replace the faintly depicted side port covers with .033 inch discs punched from .005 inch plastic for a sharper look.
Finally, although horizontal strengthening strakes were represented on the front and sides of all the kit mounts, these were actually only fitted to Kagero’s forward gunhouse (as stiffeners to resist seas coming over the bow). Accordingly, I removed them from the two aft gunhouses leaving their fronts and sides smooth.
So much for the easy part – now come those tiny footrails for the gunhouse sides!
I started with the forward mount. After anchoring the U-shaped upper rail to the brass panel on the gunhouse rear with a dot of super glue, the rest of the piece was lightly secured to the sides with dabs of liquid plastic cement as were the two lower side rails. The cement doesn’t work on brass, but is softens the plastic just enough for it to grab the brass legs and tack the parts in place.
This long piece is designed to be shaped around the perimeter of the gunhouse roof…
…but the complex bends required seemed to be too much to keep track of for a single part, so I cut it into left, right, and aft sections which can be bent to shape and applied separately. The side parts are a pain to get just right, but here’s the portside piece ready to go:
And in place.
The starboard top piece was similar. I’ve also attached the curved section for the back edge of the roof.
The various smaller roof rails were then set in place.
Lovely precise work Tim… Another little gem takes shape in the dry dock :+1:
Thanks John!
Finally come the Infini brass barrels which fit directly into the kit canvas bloomers.
The plastic kit barrels would have worked just fine, but these lovely brass parts come with open bores and perfectly round, subtly tapered tubes without any mold lines.
The simple 6 piece Tamiya forward gunhouse has thus ballooned into a complex 29 part assembly – but it does look better!
Now to do this two more times… :grimacing:
Doesn’t just look better, looks gorgeous :star_struck:
Seeing what you’re doing here, Tim, makes me want to crack open the stash and start another ship :saluting_face:
Dooooooooo it…you know you want to… :smiling_imp:
Do it … follow the path to the dark side …
Wow … wheres this simple build you were on about doing Tim ?? :rofl:
Oh, I do Rory, there’s not a doubt in my mind… But time is not my friend at the moment :disappointed:
I certainly have spent my fair share of time on the dark side of the hobby, John :grin:
Vader
I can feel the power is strong inside you - Join us Russell!
Best intentions… my mistake was getting that damned Infini detail set. It is so gorgeous, it just draws me further and further in. Not only that, I completely lost my head and just ordered a bunch of unnecessary 3D printed goodies from China as well. At least there hasn’t been any scratchbuilding…
Anyway, how else will I be able to entice Russ back to the salty side…? :grin:
Well, if I win the lottery tonight, I can call in well to work on Monday giving me heaps of free time :crossed_fingers::grin:
PS at some point I will do a photo feature of Dauntless :wink:
PPS for the time being a wing thing or two will keep me occupied :slightly_smiling_face:
With the exception of removing the molded strengthening strakes, the now smooth-sided aft gunhouses received the same treatment as the forward mount.
As previously, the rails fit well and were secured with dabs of liquid plastic cement applied with a fine brush. I’m not nuts about the weak bond, but the thin cement is quite a bit neater and easier to control than super glue. I just have to remember to use extreme care in handling these assemblies as I work with them.
Here are the portside top rails for the two gunhouses bent to shape and ready to install. They may not look like much here, but I found them fiendishly difficult to bend into the exact right shapes needed to match the complex roof lines!
Once correctly shaped though, Infini’s well-designed brass parts do fit perfectly on to the kit parts.
Attaching the rest of the roof rails and the barrels was straightforward. Except for painting, Kagero’s 12.7cm main guns are now done!
With the major weapons sorted out, it is time for the secondary 25mm antiaircraft batteries.
I’d previously prepped Tamiya’s kit 25mm AA platform which was adequate but, admittedly… unexciting. The molded-on 25mm AA ammunition boxes were particularly disappointing, but my thought was to cut them away and replace them with either the boxes from the Infini set or other aftermarket resin parts.
Despite the mismatch of the Tamiya and Infini nonslip treads which initially led me to forgo the brass replacement platform, in the end I just couldn’t pass up Infini’s better detail. I glued the upper and lower halves of the brass deck together and evened up the edges with micro files and sandpaper. The rails had come already attached to the brass deck, but I separated them to ease forming them to the multiple bends of the platform.
After shaping the rail parts, I reattached them to the platform with super glue. The seemingly simple curves of the structure were surprisingly challenging to match smoothly, but the results are worth the effort. I like that Infini also incorporated the safety netting into the etched rails.
The underside was even better detailed with two turned brass support pillars and no fewer than 15 etched support girders. Nice!
Unfortunately, all that underside detail will be hard to see once the platform is fitted aboard…
…but it will still be visible if you get down low!
These are the kind of details that distinguish the model. Structural elements such as the brackets and braces poorly represented in plastic (due to the restrictions of the medium when pouring it in molds) stand out when replaced with photoetch.
Excellent display! :+1:
Like Nikos said … the detailing really pays off and shows it off far more effectively :+1:
I know what you mean Tim; I had many similar railings at my ARKTIKA Icebreaker which also needed complicated bendings and curves. And you always have just one or two tries until the thin etched rail will break…
Great work from you so far :ok_hand:
Thanks guys!
Here’s the aft funnel attached to the new AA platform seen from above.
Next up: more etched details for the funnels.
