Interesting M1135 Stryker NBC
I’m glad the photos help. I looked into a Black Dog set a few years ago, and based on what came with it decided I could just as easily do it myself.
The photos helped, thanks! Not sure I will be able to actually scratch build the clamps and mounting brackets though but will try one day. I am saving up the used PE frets to cut up to attempt them but still not looking forward to it.
After packing away the airbrush a couple weeks ago, I unpacked it today as the weather was perfect after being 28F a couple weeks ago.
I started the NATO camouflage on the M1135. The right side has the correct camo pattern as I have two photos showing the full right side. The brown does carry over to the CROWS mount so the brown goes at least that far over the top.
The left side I am sure has more brown but is hard to see as the photos I have don’t show the full left side.
The front might have more brown to the left of the photo but is hard to determine from the photo I have because of the glare.
The rear is as close as I can get from what I can see.
I did not paint the camo on the top yet as I do not have any photos showing the pattern. I will have to guess the pattern after trying to follow the paint demarcation lines from the reference photos I showed above.
Strykers are awsome!
That and the HEMTT / LVSR family line.
Still need to finish these
That’s where a generous amount of stowage comes into play.
Take into consideration that Stryker NBCRV only having a 3 man crew. So no 10 rucksacks.
True enough! But three rucks along with three duffels will take up a lot of real estate. Then you have your camo net bag, you camo pole bag, and for many modelers - a deployment’s worth of boxes containing Mountain Dew and Coke. Go bags stay inside for easy access.
That is looking good.
It is supposed to be even warmer tomorrow so I might attempt to paint the top camo pattern. It won’t be 100% correct as I have nothing to go by except the above reference photos already shown and none of them show the top view. I will add some stowage but I can’t find any photos of any actual Stryker NBCRV’s loaded up so my stowage will also be fictional.
@Small_Designer, very nice conversions. I have seen your sets on 3D Wild and have the DVH set for the Trumpeter kit on order. Still waiting on it. I ordered it to attempt this SOF Stryker in Syria. I have the Trumpeter M1133 I will use for the conversion along with the Legend M134 minigun set.. I also have the Priamide parts including the blast panel set that I will modify to fit, hopefully. The Priamide set also includes the headlight extension arms. The rear stowage basket I got from the AFV M1126 CROWS-J kit.
@18bravo and @HermannB, Yes, I was planning to add stowage but can’t find any photos of the Stryker NBCRV loaded up. I only found this one and other similar photos and this is as much stowage that I can find on them.
@Karl187, thank you.
One thing you might try is looking at other similar vehicles to see if they have the same overall pattern. The same overall pattern was tweaked to not only be used on olde M109 series, but also the M109A6, and even the PzH2000, as I showed several weeks ago. They used exactly the same base pattern and tweaked it where it needed to be stretched. You might find that another wheeled vehicle has the same pattern you need - then oyu can simply transfer it to the top.
I did just that as you said. I looked at the M113 and found it is not the same but might be close enough.
If you look at just then upper portions of the sides you’ll see a striking similarity to the Stryker camo.
@twong
maybe you find some inspiration here. I haven`t seen any NBCRV in the field over here so I can´t tell about possible stowage.https://www.dvidshub.net/search/2.0?q=M1135
ICV Stryker over here carry only minimal stowage.
Even that “minimal” stowage hides about 1/3 of the upper surfaces on one side - helpful for filling in those gaps in knowledge. Whereas some people here invent things, others can simply hide them. :rofl:
@18bravo, I will be painting the top today and more of the left side by using the M113 paint guide. I am trying to go by what I can see on the reference photos I have to try to match up with the M113 paint guide. It will be fictional but is the best I can do.
@HermannB, thanks for the link. I am a member of DVIDS and had looked there before but not much showing the M1135 with stowage. I do have some backpacks and other items that I will use on the M1135 but will keep it minimal.
I have to dig out the backpacks and other items from the garage as I had packed them away when I thought I was moving earlier this year so have to remember which box I threw them in. Will do that after I finish painting the rest of the kit today. No more painting after today even though Wednesday will be even warmer but I have a ton of errands to do for my parents and Thursday too. It is going to rain all day Thursday anyway and Friday too. The cold weather also returns next week and we will be back into the 30’s and 40’sF so looks like my painting days are over, again.
Was able to finish painting the camo on the M1135 today. The top is totally fictional but I did use the M113 NATO camo template as a guide.
Here are the backpacks I will be using on this build. I got them from a friend but it is only a partial set. I think he said they are from Legend. HermannB said only 3 crew members so I will only add 3 backpacks. I will have to find some other items to go with the backpacks.
Just wondering, but aren’t the backpacks contaminated when they hang outside a NBC (Nuclear Biological Chemical) recon vehicle?
Makes more sense they stow them inside… isn’t it?
There is not too much space inside the NBCRV. As is in any other Stryker. :frowning:
Aw come on, ain’t nothing like a radioactive MRE with a sprinkling of mustard gas :face_with_spiral_eyes:
