Was wondering or should I go RFM???
I have the Miniart 234/1. in the stash. I am happy with mine. Mine is the one with the open top and the 20mm. The interior is nicely detailed, It’s the most detailed of the 234’s available I believe. It also comes with molded plastic tires instead of Vinal if that is an issue. The RFM will be the easiest to assemble but the ones who have built the Miniart kit said they had no issues in the build.
This is the one I have.
review with interior
Miniart 1/35 Sd.Kfz.234/1 Early Interior Kit (35410) Review
review without interior (has a partial interior)
Sd.Kfz.234/1 Schwerer Panzerspähwagen (2 cm) Late Mod., MiniArt 35413 (2025)
Awesome news thank you…
Go to Scalemates, download the instructions for the Mini-Art 234 you want and the RFM 234 you want. Compare what’s required to build either model.
Lot of it depends on what you like working with. For instance PE like the Mini-Art has on the jerry cans vs a plastic Jerry straps like RFM & Dragon offers.
Go with the one best matched to your interests & skill level.
I find Miniart kits to have too many parts sometimes when it´s not needed. I rather go for a RFM or Dragon kit.
Anyway, the MiniArt 234/2 with Luchs turret looks great!
I’m building this kit right now. Overall it’s a nice kit. It’s very detailed inside and out. It seems well engineered. But there are lots of small parts. You’ll need a good sprue cutter to get the parts off and there’s lots of parts clean up required (at least in my case). Track Link has several blogs going on the various 234’s. One’s just starting up on the Miniart 234/1.
Hello there . If still wanting an opinion.
Im building the miniart , none full interior 234/1 late kit and all that’s missing is the engine and two hull radios. Looking at the rfm instructions, the rfm kit has more parts , even without the engine and much much more etch, even in the hull interior. Just my 0.2p worth .
I am in the process of building MiniArt 1/72 Stug lll. MANY more parts than Dragon’s equivalent - some extremely tiny! Quality is certainly good, but final product is marginally better than Dragons.
