I am wondering what wire should I use for modern Israeli armor (tanks, APCs) to truthfully represent the antennas in 1:35 scale? Will 0.2mm wire be more or less accurate? 0.2mm would be the equivalent of 7mm cable in real-life ( 1:1)?
Any recommendations?
Hi Daniel,
IDF uses US made antennas. The AS-1729-RC is the most commen antenna. https://radionerds.com/index.php/AS-1729~VRC
Can´t tell about the rod diameter, but the link should give some useful informations.
The antennas have two 4’ sections and are 8’ long total. In 1/35 that is 2 3/4". I use o.o20 plastic rod for my antennas. I also heat the ti p so it mushrooms to replicate the antenna safety ball that they have.
These turned brass aerials are literally the topping on the cake you have just completed. Why spoil the hours and hours of work you have just spent? Doesn’t your model deserve the best?
This looks like a good set, but it is not really a US antenna, also used by the IDF. It looks to be a Korean-specific antenna. The lower antenna section is different as it is not a straight piece, but has a smaller section at the bottom. The upper mast section and the rest of the set is correct for a US antenna though. I would use the bases and hold down clips/ropes and replace the mast section with a piece of straight styrene metal rod.
