Hi everyone,
I am starting a new 1/35 IDF project based on the Diamond T 980/981 with the M9 tank transporter trailer, and I am trying to document a particular modification seen on Israeli M9 trailers.
The idea for the diorama is an Israeli Diamond T/M9 combination transporting a recently captured Arab T-54/T-55, probably before the tank was refurbished or converted into a Tiran. I already have the files/parts for the Diamond T and M9, so at this point I am concentrating on making the trailer as accurate as possible.
I have found several period photographs showing what appears to be the same Israeli modification. One particularly useful photograph shows a captured T-54/55 marked “3054” loaded on an M9. Another shows a whole line of Diamond T/M9 transporters carrying captured tanks, and the closer photographs give a much better view of the trailer structure.
The feature I am particularly interested in is the additional structure along both sides of the M9 loading platform.
At first I thought these might be raised side members, but after comparing the photographs more carefully, I don’t think that is correct. They appear to be lateral extensions of the loading deck itself, approximately level with the original deck, effectively increasing the usable width of the trailer. The outer vertical face then forms the visible side of this added structure.
The fact that several Israeli M9s in the same photograph appear to have the same arrangement suggests that this was not simply a field modification to one trailer, but possibly a reasonably standardized Israeli modification.
I am now trying to determine its actual dimensions and construction.
As a starting point, we have been using known dimensions visible in the photographs as scaling references. The captured T-54/55 is especially useful: its overall width should be approximately 3.27 m (93.4 mm in 1/35). The M9 wheels/tyres may be an even better photographic reference because they are much closer to the same plane as the trailer modification and therefore introduce less perspective error.
From the photographs, the questions I am currently trying to answer are:
- How much width was actually added to each side of the original M9 deck?
- Was the extension made from plate over a welded frame, or was it based on channel/box-section members?
- Did it run for the entire usable length of the loading deck, or only the central section?
- How exactly was it attached to the original M9 frame?
- Were the additional tie-down rings part of this modification?
- Was the rear/ramp area modified at the same time?
- Was this an IDF-designed modification, or does it correspond to an existing post-war M9 modification used elsewhere?
My current plan is to reconstruct the modification in CAD and print the necessary parts in 1/35, but I would rather base it on evidence than simply make something that “looks right.”
If anyone has additional photographs of Israeli Diamond T/M9 combinations — especially rear views, front three-quarter views, unloaded trailers, workshop photographs, or close-ups of the deck and frame — I would be extremely grateful.
Even photographs where the trailer is only partially visible could be useful. References from books are also very welcome; if you know a publication containing good photographs of these Israeli M9s, please let me know the title/page and I can try to find a copy.
I will attach the photographs I currently have and mark the particular lateral structure I am trying to reproduce.
Any corrections to my interpretation are very welcome as well. If I am misunderstanding what this structure actually is, please tell me — that is exactly why I am posting before committing to the CAD work.
Thanks in advance for any help!
Rafael
