Hi all,
Made one or two dioramas before, but never a full picture like this will end up being. I’m very lucky to have some help from my better half, she has always wanted to make a diorama with me. It’s much needed on something of this size. I didn’t think it was going to be too too large, even though HG pointed out it would be quite massive, I didn’t put it together in my head until I started assembly of the building.
The command element of the Panzer group has stopped to resupply and regroup before moving to a more defensive position.
Here’s a rough layout
Using the “Freight Shed” building from RT-Diorama, two ICM Wehrmacht 3 Axle Trucks, the RFM Panzer IV Ausf. J in command form, and RFM’s Panther G.
I’ve built one of the three axle trucks so far, as well as the Panzer IV. The Panther is in the works.
The truck needs paint, but I’m going to do that side by side with the GF and her three axle truck. The Panzer IV needs the weathering finished up, but everything is going to get weathered together for uniformity’s sake.
Here’s my three axle and the Panzer IV.
First time soldering PE parts, had a blast. These are from the RFM upgrade PE set.
Panzer IV all ready for paint.
Panzer IV as it awaits full weathering. I wanted it to be a last ditch effort command conversion. Took a working turret from one damaged hull, and then a working hull. Did the minimal necessary conversions, added some camo, and then added the white winter camo to top it all off.
Here’s the Panther in its current form as I build all the little Rochm PE bits. I’m a sucker for PE as you guys will end up seeing.
Next update will have a rough layout of everything on the base. I’ll also figure out how to downsize my images so they’re not too big for direct posting.
Thanks for stopping by!
