Just Another Tamiya Tiger
I started with Tamiya’s Kommandant Otto Carius version of their Pzkpfw VI Tiger Ausf. E. I got the kit from a fellow club member. It sat ignored on the shelf for quite awhile because of the individual link tracks that were included. The instructions would have you glue them together, let them set up for 30 minutes, and then thread them around the wheels. This seemed to be a recipe for frustration and potential disaster. I had seen 3D printed tracks from a company called T-rex, and decided to order a set. I was apprehensive at first, but glad I did in the end. They were easy to assemble, workable, and well detailed. The fit is so precise you have to beware of some minor flash on one edge of some of the the links. Easily cleaned up with a fine grade sanding stick. The links are joined by using two different type of pins. I broke a few trying to insert them, but T-rex gives you plenty of extras. They say no glue is necessary, and that’s true for the most part. But I did have a few work loose, or fall out. For a loose pin, I used a sharp toothpick to apply a tiny drop of thick super glue behind the head of the ‘pin’ and pushed it back in. I did the same when replacing a lost pin.
The Zimmerit was an Atak product and using it was surprisingly easy. They also included several solid resin pieces, two types of gun mantlet, the turret escape hatch & the two pistol ports. The only modification needed to the kit parts is to sand off the molded on pistol ports. They also included some pieces of ‘damaged’ zimmerit that could be used if desired. Other than a few scratchbuilt details, the only other additions were Tamiya’s PE engine screen set, a two figure set from Alpine, and decals from Peddinghaus.
I added the power lead to the blackout light using a carefully bent piece of brass wire.
The covers over the exhaust pipes were thin metal and usually took a beating. So I added a few dents and holes to mine.
A small detail that was added are the lower brackets for the spare track links. They were made from some small Evergreen plastic angle.
The figures came from an Alpine set and were well detailed and they captured Leutnant Carius’ features quite well.
There are certainly better detailed Tiger kits available, but with a few add-ons and some TLC, I think Tamiya’s Tiger builds up quite nicely. Thanks for looking, questions or comments are welcomed.
Those tracks look fantastic, the fact that you’ve painted them so well adds to the excellent job you’ve done.
Really nice looking Tiger, thanks for posting.
Watto. :medal_military: :beers:
Excellent job Al. Great build and finish on that Tiger. Figures came great too!
Thank you, much appreciated. I don’t want to sound like a shill for T-rex, but I was happy I took a chance with them. I thought that inserting the pins might be problematic, but it turned out to be much easier than I feared. The guide teeth are somewhat fragile and there were some broken off of a few links, but I had enough to do the job. Tamiya’s instructions called for 100 links per track, but I found that 97 was the magic number.
Thank you very much for the compliment.
Very nice job Al, Otto looks excellent.
I agree… it looks great.
I love T-Rex tracks, they are easy to work with.
35 to 45 mins you finish up a set of tracks (Panther / Panzer I for me ) easily.
Thank you very much, Matt. See you at Armorcon.
Thank you. I agree about the T-rex tracks. I don’t usually buy after-market tracks, but in this case I was very glad that I did. If I’d tried to use what Tamiya supplied, this project probably would’ve ended up in the trash bin.
Sometimes the original tracks are good enough.
But my Dragon Panzer I and Meng’s Panther… were impossible to work with…
To me, single track links that require to clean up 4 sprue attachment points … that kills any mojo you have left.
You’re right…destination trash bin !!
I could not agree more, I’m usually quite happy with ‘link & length’ tracks, and even vinyl tracks in some cases. But I refuse to deal with tracks that require four or more parts to assemble each link.
Very nicely done! I will have to try T-Rex tracks.
Thank you very much. I was happy with the T-rex tracks. In fact, I’ve purchased a second set for a Sturmtiger I have. My only quibble was that some of the links were damaged. The guide teeth were broken on a few. But I had enough to do the job.
How many extra tracks were there? I have never used 3d printed tracks since I heard conflicting reports on quality
The two brands of 3D printed I’ve used are excellent.
  1. Quick Wheel’s Quick Tracks snap together securely and don’t need parts clean up. Have used a set on a 1/35 Panther D and was delighted with the results. Took ~30 minutes to assemble the tracks.
  2. Ryefield Model’s 3D printed Pz IV tracks. Excellent result but gluing track pins in is more time consuming. Took a couple of hours to assemble.
  3. Have a few TRex sets but haven’t used them.
Acquaintance had a TRex set get brittle and crumble to dust when unpainted 3D resin was left exposed to light.
Have purchased additional sets of Ryefield & QuickTracks and would use again.
T-rex included 210 links in their set. Tamiya’s instructions called for 100 links per track, which would’ve left 10 extra. Seven links were damaged, which might have been my fault as I said. But in the end, it turned out that only 97 links were needed for each track. I was concerned about losing the pins needed to assemble the track links, but there were more than enough extra of those. As for quality, I can’t speak for other brands, but these were highly detailed, well printed, and required only minimal clean-up to assemble. In fact, I’ve ordered another set for a Sturmmorser Tiger that I have. If you have any other questions, I’d be glad to answer them.
I don’t know anything about them crumbling, I’ve seen no evidence of it. I base coated mine with Rustoleum Flat Red Primer straight from a rattle can. I then used various enamels and acrylics to weather them.
Excellent work on the Tiger Ausf. E project. The track issue is something many modelers struggle with, so the T-rex solution sounds like a smart choice. The precision and extra details really make a difference on these iconic vehicles.
The Dragon and Tiger rivalry has always been a fascinating theme, whether in history, models, or games like dragonvstiger.com.pk. Looking forward to seeing more updates on this build!
Thank you, Here are some photos of the Tiger in it’s final habitat, a diorama I call “A Pair of Aces”.
