King Tiger - Initial production rounded turret
Here is the next sacrifice to the bench …
Dragon premier kit of the King Tiger.. and one of the rounded turrets. (We don’t need to get into “it’s not a Porsche turret,” we all know it now)
Looks like a nice kit after first inspection. Have ordered some Zim for it, and it will get a decent of amount of PE where it’s needed. Won’t start until I get the zimm delivered so that can go on first.
Not sure on the final finish…
On a side note … I will also be building this at the same time …
This will be OOB apart from masks and seat belts.
Did any of these early KTs last long enough to get Zimm? They (the first 50 or so before the later turret took over) rolled out before Zimm was a thing, and I thought most were lost in France.
Everything I have seen says that the first 50 all had Zimmerit. The tank this kit is based on certainly had it.
OK my bad - it was on the first ones but later discontinued. Showing my ignorance of German tanks!
Pretty much September '43 to September '44. On year of weird paste. Eighty years of modelers scratching their heads and making sour faces.
I have the same model. Good luck!
Purchased this KT when it came out, beautiful kit and loved everything Dragon was making in 1/35 finished mine as per the box art. Enjoy. Cheers.
The first three vehicles, the Versuchs Series V1-V3, did not have Zimmerit.
Yeap, and KT V2 is kept at Bovington Tank museum and is being restored to running order. It’s the oldest surviving KT in the world
Little update. The Eduard zimm arrived … However, it was intended for the Tamiya kit … So some fettling was required.
Some bits needed cutting to fit, some further plastic putty is required to blend various panels in together so it all flows.
Can start the normal build process now.
We’re gonna need photos here of something that cool.
Back on the KT for a few days …
Did the drop arms and the wheels etc. All ready for priming soon. Also finished up the rear engine plate.
The white areas are perfect putty and it’s just to blend the Eduard Zimm edges together to blend it all in.
Been a bit under the weather so not much modelling time , but got a few things done today on the KT.
Added some hull detailing on the front, namely the headlight cable and new hatch pulls.
And the engine hatch along with the PE grills
I also drilled out the rounded part as the kit part is solid. I have also removed the moulded on fuel overflow pipes and drilled out holes ready to add shaped wiring on those.
