Land Rover Vigilant
In 1956 vickers as a private venture set about developing an ATGM . Wire guided and man portable it also lent itself to vehicle mounting latterly the Ferret Armoured car .The system was also fitted to various land rovers initially as a carrier and eventually a fully fled fire system.with the advent of SMM set a germ of an idea developed.
TIL “The longest range wire-guided missiles in current use are limited to about 8 km (5.0 mi)” (wikipedia)
Outrageous!
So were to start ..I needed a serie 2a . The obvious choice is the Tamiya pink panther I’ve plenty in the stash ..I also need to use the Tamiya ambulance the revell 109 and the Ak swb base Land Rover ..hopefully it will become clear .fair bit od scratch building the dp Land Rover etch brass set and SMM vigilant kit
As with anything Landy related - watching with interest.
Cheers mate
I needed to make a few alterations to the seat base of the pink panther so a little cutting a scratch building required.
Here’s the insides of the missile:
The different kit parts were a little tricky to get to fit with each other but some work with a file and knife provided the desired result..as with most of my land rovers of this era I gave the underside a little stipple of Ak texture paste the underside of early British land rovers had a rough underseal applied to them it also helps depict the build up of grime ..
Mock ups of the missile mount system and stowage boxes
Love me a Landy as well.
Following with interest as to how this builds out as I’ve got the old
Esci 109 Paratroopers in 1:24 in the stash.
That, and anything carried by mobile Inf that can take out armor is always of interest.:wink:
Dave🙂
The launch system….
Little bit of 70/80s style camouflage net to add interest
Mocking up the launching system
Now we’re talking!
I never even knew there was L/R borne version of this. Some serious kitbashing being done.
I’m particularly impressed by the netting.
There were a couple of variations this was the last one mate
Thank you
Some base coat before the main colour goes on
