I have a technical question for the experts here. Is there a standard length for radio antennae on German WW2 AFVs (ie tanks, armored cars, half-tracks etc)? It seems to me that there surely would be, but I can find no reference. If there is, what is the 1/35 scale equivalent?
Short answer is that the āstandardā German WWII AFV used 2m long antennas.
There are a number of different radios that were fielded, though, so this is not an absolute. For instance, tanks equipped for ground-to-air liaison used a 1.4m long antenna.
However, most tank radios used the 2m long antenna for tank-to-tank communication which includes most command tanks with two antennas (both the 2m long type).
In 1/35 scale, the math works out thusly: 2000mm / 35 = 57.14mm long.
This discounts radios that used frame antennas or extendable long mast antennas. It also doesnāt include the infamous āstarā antenna which was 1.5m tall not counting the smaller āstarā elements.
This website might provide you some info as a springboard for more in-depth research:
That link to German Radios is amazing especially the color photos. At least for the Pz III and IV, wouldnāt the length of the antenna rest be a good measure of the length of the antenna?
Jack
The antenna trough on the Pz I-IV is a bit longer than the antenna, proper. Many of the wooden trough designs also incorporated a storage pocket for a spare antenna under the open top trough. However, the wooden trough is pretty close in length to the antennas.
Some tanks, like the Tiger used a metal storage tube for the antenna. On the Panther the antenna storage was contained inside the large tube usually associated with storing the cleaning rods. Metal antenna storage tubes were also used on some other AFV types.
Command Tiger and Panther tanks added additional antenna storage brackets and / or tubes for their command radio sets.
Does this represent a real antenna, an antenna mount with a plug installed, or is it just made up?
I have also noticed that some antenna bases are really anemic compared to others. The first picture above is from a Meng Jagdpanther. The antenna base on a Dragon Jagdpanther is significantly more robust. Is that a real variation in the antenna base or did someone goof?
These are the antenna base mounting studs with rubber insulators. The antennas are hollow copper with a split at the base end, they slide over the stud and are tightened on with a wingnut clamp. Studs should be of a standard length, canāt comment on differences between Meng and Dragon, although I believe there is a simplified late war base, I need to find a photo though.
Iāve never even seen the two in the front row. Then again, try finding photos of them. Didnāt see these at Munster, Koblenz or Sinsheim, but then I wasnāt looking for them either.
