Leopard 2A4HU - Meng
One of the first tank models I built was a Dutch Leopard 2A4 from ESCI-Ertl. About thirty years ago I was very much impressed with the model as well as with the real tank, so I wanted to re-build the model but the ESCI kit was not or hardly available. I did not like the Revell and Hobby Boss kits so I became really excited understanding that Meng was releasing this kit. Meng had a good reputation because of other subjects already. After a bit of research, it turned out that to convert it into a Dutch vehicle, I had to ask the extra sprue with the Dutch parts from Revell customer service (their A4/A4NL kit was no longer available anywhere).
Shortly after the Revell frame arrived (biggest thanks to the Revell customer service, their helpfulness is exemplary), I also bought the ET-Model upgrade etched set and metal-resin gun barrels from RB Models and the Leopard Club (not planned, I overordered them by mistake), the 6+2 smoke grenade launchers assembly and an FN machine gun (also from Leopard Club). When all the necessary parts were collected, the news exploded like a bombshell that the Hungarian Defence Forces had purchased 44 2A7+ tanks and until they arrive, 2A4 tanks will be loaned for training purposes. Wow! A perfect subject to my Leopard 2A4 project!
Since the configuration is always questionable, I waited almost two years to get the necessary reference photos. A friend of mine, Péter “Petibá” Tóth gave me two specific parts that are only found on Hungarian Leos: the antenna mounting and a strange shaped frame behind the loader’s hatch. He CAD modelled them himself using reference photos and 3D resin printed.
After carefully checking the Hungarian tanks it was found out that the smoke grenade sub-assembly resin set is not perfectly matching to the real vehicle, so another friend of mine Csaba Mészáros has re-designed and 3D printed both sides. So I had all parts for a quite realistic configuration to be started.
The project progressed relatively quickly because I managed to spend about 2-3 hours every night on it, and also because I had already built a Polish Leopard 2A5PL tank using a Revell kit, with Voyager detail-up set and resin gun added, back in 2021:
I tried to use as much of the ET Model etch as possible, mostly in the engine cover area. Serious questions and research was required to find out whether the pioneer tools and the field-fuel-filler tube are part of the Hungarian configuration or not. The first vehicles on display had these accessories not fitted to the vehicle, so I had to find out whether these are used in normal use or not. I managed to make photos about a real vehicle and to speak to an tank crew member at a military exhibition who reassured me that these are used on the field and only removed for exhibitions. Similarly, the towing cables are taken off because that is the only way to get the tank on the trailer (at least this is what he said).
I had a serious problem with not being able to solve the gun barrel from one single set because there were some minor damages on each. I ended up combining at least one part from each set, even using the very end of the original Meng plastic barrel. Because the positioning of the barrel elements didn’t want to come together smoothly due to the many different internal dimensions, I drew a black line down the thick (resin) part in the middle of the barrel to give the centre line of the barrel when glued and inserted.
When I finished the body and took the model out to the garden to take photos, I lost one of the main wheels somehow. Luckily “Petibá” has a spare Meng 2A7 kit for such (hyena) purposes, and he was so kind offering me a spare wheel set. He also told me that the frame that hugs the small orange lights on the front of the hull can be installed from the Meng 2A7 kit. This little item was also added to my Leopard.
When I was making the turret, “Petibá” also drew my attention to the fact that, unlike the Meng model, the area under the antennas had been cut out. So I had to remove the antennas and drilled out the two areas on the assembled turret, then made the base under the antennas out of styrene parts. The right hand side was pretty straightforward, but the left hand side hole has an angled bottom that caused me lots of trials to make somethan that does not slide down into the turret. Could tackle it in about an hour.
Not all the upgrades were perfect, but I’m happy with the result.
Unlike my usual practice, I first sprayed the model with Gunze Grey 1000 primer, then went over it and corrected a few spots. The result is pretty clear and looks like a computer rendered CAD drawing to my eyes.
I could also make some good photos about that strange shaped frame on the turret top and have seen that there are two stripes attached, which are missing from the upgrade part design made by “Petibá”. I could add them using plastic nappy cover, the material I always use to imitate canvas or stripes, belts like this. The buckles are added using the Eduard T-72M photo ectch parts, designed as clutches to the T-72 fender boxes. The result after the grey primer is outstanding, I think.
The next day I applied my preferred 1500 black Finishing Surfacer. How cow, it is an Imperial Destroyer! I had some desire to keep the model in black to be honest…
Now I’m going to set the model aside for a few days and first mentally prepare to paint on the Hungarian camouflage.
Happy modeling!
Tamas
I’ve had the same idea of a modeling subject
Hi Dan, I hope you will be able to do that. The Hungarian camo is pretty much unique!
Tamas
Keep upi the good work. :slightly_smiling_face: :slightly_smiling_face:
I will also have a look over your shoulder from time to time, Tamas! Good start on this project, a good eye on the details as usual from you and good luck on this difficult and unusual hungarian camo. Too bad all your extra work won’t be really visible in the end.
Have 2 of the Revell 2A4 kits in my stash, one is already built as a greek one. You may remember from the Leopard 2 Campaign some years ago. Also a difficult camouflage. About the other 2A4 I haven’t decided wether to build a dutch or austrian one. But sure not this year …
Torsten
:beers:
I even bought decals for this version
Hi Dan,
You still need the extras to have a proper Hungarian version. The smoke grenade assy and the FN MAG can be purchased from Leopard Club, the mounting frame and the antennas are to be 3D printed or scratchbuilt. Both of them are doable.
Regards,
Tamás
I have bought those items.
I’ll need to look at photos to see what else I need to add.
I tried to find back the walkaround pics taken by Mátyás Pánczél but could not. His photos are great references, I also followed them a lot.
Will ask some buddies over here if someone has the link saved.
Hi Torsten,
I do remember the Leopard campaign, it was a great and good fun project to join and build the tank (or sisters). I liked your Greek version, it looks great to my eyes.
If I would build a second tank, I would definitely run for the Dutch version as it has some extras. You can probably get it from an old Revell kit (it is an extra sprue if one did not use it up) from the 2A4/2A4NL or the 2A5/2A5NL kit.
Good luck and keep up your great work on your build thread, I regularly look at it and like very much.
Have a great day!
Tamás
Dan,
Got found the reference pics by Mátyás Pánczél (interestingly: his names translates to English as “Matthias Armour” - a real Hungarian family name and Mátyás is a real tank expert).
Good luck with your Leo!
Tamás
Hi Dan,
There is a zipped archive from various photos available on this link too from Petibá:
http://www.toff.hu/21910.zip
Tamás
Hi Tamas,
did the Hungarian army also get Bergepanzer 2? Where could I find photos of it?
Viktor
HI Viktor,
Yes, the HDF also got Bergepanzer (at least one).
Two photo I took myself in Tata with an interesting decal.
Hard to find enough photos but try google it. Similar camo, same colors like on the Leo 2A4 tanks.
Tamás
Thanks
I will upload some Bergepanzer 2 photos later, at the moment HDF has one but I think it is still operated by KMW.
Some more Leo 2 photos in the meantime.
https://www.mhrf.hu/index.php/nggallery/kmw-leopard-2?page_id=149
Hi Ádám,
I was not aware of the new reference site link, thank you! Though I have some of the photos from Mátyás Pánczél, the 2021 photos will surely help me in the painting process later.
Tamás
https://www.mhrf.hu/index.php/nggallery/muszaki-harcjarmuvek/bergepanzer-2-kecskemet-2021?page_id=166
