Hello what are your thoughts on spraying and the color accuracy of Lifecolor paints? Specifically 5-O Ocean Grey, 5-H Haze Grey, 5-N Navy Blue and 20-B Deck Blue. UA621,624,625,626. Thank you
I use Lifecolor paints regularly and I get good results with them. They should be used over a good primer such as Tamiya rattle can, because they can peel when masked if you don’t. They also brush on well. I can’t speak to color accuracy because I am quite color blind.
Is it a red/ green thing or a black and white thing? I have known people with both types. The black and white only guy did scratch art of wildlife. I have some of his work.
It’s a red/green/blue/green etc thing. When I’ve been given the “can you see a number in the circle test” I don’t see any numbers. I don’t miss what I’ve never seen
