OK I have a question for the group.
What is the piece of equipment I have circled ?
FHMUX, or TD-1456/VRC Frequency Hopping Multiplexer.
Is that from my walk around? I can’t even tell any more.
I also have a couple of your Stryker bundles and I don’t have this particular pic. Maybe it’s not part of yours but I’ll wait to see the OP response.
It is from your walk around.
Fantastic reference package that is
Well, that clears it. I’m missing a picture ![]()
You went through over 1000 images? It’s up to over 1500 now as I keep adding, so I can’t even keep track.
1000? No, I only have these two folders that you sent over year or two ago. I though that’s all you had. Do you send updates to folks that purchased previously with new photos?
Somehow they didn’t come through. That would be on WeTransfer. There’s a time limit on how long you have to download them. Those two might have come right in under the wire. There are several more. I’m glad you caught it. Send me your email address.
Here is another Question
In the first photo you can see the traditional seating, in the second it appears to be seating light the Bradley. I am assuming that this may be a DVH upgrade for crew protection. Can anyone shed a little light on this.
Thanks
The newer seating mitigates against blast effects on the spine.
So this upgrade would have been done with DVH hull upgrade or later then.
Is that correct
It was done before the DVH programme started.
HermannB is right—the blast-attenuating seats were an earlier survivability change, not something introduced with the DVH hull. On a model, I’d treat the seat type as a separate detail from DVH features unless you have a specific vehicle/date reference.
H-H is correct. I’ve been goofing around this morning, but the yes - the first time I saw those types of seats was in '07.
Thank you gang
As always, great to come here and learn a bit every time.
