M1130 Command Vehicle (CV) with Slat Armor
Mail call! My second slat armor conversion kit has arrived along with a bunch of goodies! Thanks Black Ops Models .
The M1130 Command Vehicle awaits it’s bird cage wrapping.
I’ll keep an eye on this thread. I bought the Eduard PE set for trumpeter kit to recreate an M1130 I took photos of in Afghan. If you hear anything on any posts regarding interior with the single mine blast resistant seats (at least I think they are), hat would be awesome :+1:.
I will be watching as well I did the Edward set. What a pain in the butt.
Siball69 and Thor1822, this slat armor kit is Superb. Check out this full build review of the kit on the M1126 ICV.
The MC build should go smooth as the external cage fittings should be identical to the ICV. The blast shields on the upper deck may require some tweaks, as the larger antenna housing on the MC may pose a fit issue. Time will tell.
Slat armor full buld review can be found here. https://www.amps-armor.org/SiteReviews/ShowReview.aspx?id=15393
Ok just seeing if this is the same kit as on their web page it is listed as AF35126.
Yes, it is the same kit.
Same here, I’ll follow along and see where this goes. I too have the Eduard PE flat set but not looking forward to using it anytime soon. So, it will interesting to the end result of those 3D printed sets. Good luck!!
