M134 Minigun questions
Lets see… Rate of Fire…Cost per round…Class 3 license… insurance…
I wonder the actual cost per minute of operation is?
Hahaha! Yes!
I’m using the Legend resin/3DP kit for an areas suppression weapon on my imaginary AGDS.
The tricky thing will be the belts. They’re resin, and I’m sure a bit tricky getting off the plugs.
I have used quite a few of Legend’s products, given that I helped them with a lot of modern subjects over the years. I even gave a tutorial on removing resin blocks on the archived Armorama.
I use nippers to remove the “reinforcing ribs,” a rotary saw for removng the thin parts from the resin blocks, and a steel cutter to remove them from larger blocks. Finish with files and/or wet/dry sandpaper.
Examples:
