OK, so before I go any further on my M15A1 trailer as a VN , I need to clear up a few details. In the Hobby Links pics the side rails look similar to the picture in the Order of Battle book. But the ones of the one on the web are different. I’m assuming that one has been modified by an aftermarket /civilian contractor. The side parts are gone and there is plating welded on. Any comments welcome. Wayne
The photo with the two M113s is an M15A2.
The instruction sketch has features of the M15, M15A1, and M15A2.
The photo of the parked trailer shows an M15A1.
I doubt there were any M15s in US service in the 1960s.
So what’s your question?
The original M15 trailers had stowage lockers along the frame sides.
These were torched off and replaced with structural members to increase load capacity as part of the M15A1 modification.
The M15A1 modification also added the ramps over the wheels.
The M15A2 had even more modifications and parts welded on to M15A1 trailers. They can be identified by the side bumpers on the frame in front of the wheels and three rather than four oval openings on the side frames.
I saw the HL kit but did not buy it because it was a mish-mosh of M15, M15A1, and M15A2 features. The guy appears to have been working off photos that were not properly identified as to the trailer model. There was a lot going on between the side rails and on the top and bottom that you can’t see with a vehicle loaded or with the trailer hitched to a tractor. Just as a point of reference, converting an M15 to an M15A1 took 100 man-hours. To go from an M15A1 to an M15A2 took another 650 man-hours.
First of all, thanks for the help. What I’m hoping to build is a fair model of a trailer we had when I was in A Co. 92nd Engrs. in 1971/72. Unfortunately I don’t have any pics, but I remember we only had the one and all our others were M172s. I know the inner braces are different and looking at these pics it looks like the half moon holes need filled and new stake holes are needed, but is the plate on top an after the fact add on from the civilian owner? Also what other things are different/missing from the HL set? I am working with the Tamiya base kit and have the HL conversion and also somewhere in the stash, the Real Model one. Hope this makes sense. Thanks again. Wayne
Just to be clear, I am not looking to build an exact reproduction. I am an old man trying to build something to show trucks and vehicles that represent what we used so I can show my friends kids. I try for detail, but am not going for museum perfection. There is a small museum at our local veterans home and I hope some of my pieces will eventually end up there. Hope this explains my building thoughts. Any way thanks for any input. Wayne
I don’t have the HL set so I can’t say what else needs to be corrected. There were well over 100 new/different parts added during the M15A1 conversion, not counting hardware. Your best bet would be to find a walkaround of an M15A1 or M15A2 (after deciding what you want to model) and change what doesn’t look the same. A rule of thumb would be that if you couldn’t tell it was different, nobody else can either!
KL
OK, so now I’m looking to start on the Tamiya part of the trailer. Since the conversion has the open side pieces, do I use the metal pieces or maybe plastic strip to cover the screw holes? Are the metal pieces necessary? Any ideas? Also, since I will be doing it as a 70s Vietnam version I will go with it as an A2 version. Wayne
