Next task is to refine the shutters. Will be an “eyebreaking” job.
Yup, looks better than the Dragon kit one. Good deal. Too bad Trumpeter only molds them closed. I replaced them w/Dragon ones on my M270A1 Maintenance model as well.
Looks like it. It is in the same spot as the old style light w/a hood. Probably an LED of some sort.
Good start on it Hans-Hermann. If you are interested.
I made a search for the harris loop antenna and found this on Facebook.
https://m.facebook.com/groups/812442282225658/permalink/2282495058553699/?sfnsn=scwspmo&ref=share
I think this is a really nice scratch build. He built it for an M142.
Andreas
Hi Andreas, thanks for this but I will leave the Harris antenna off. To flimsy to handle and “my” Iceman had no loop antenna installed.
Small update:
I build a jig for aligning the shutters
Made the new B/O light from scratch and improved the headlights.
I missed this build. You’re doing a great job Hans-Hermann.
Olivier
Merci Olivier, now I am a little stuck with the shutters and the launch box
l look forward for you 2S3 scratchbuild;-) My Mistral build is doing fine, the missile is the best part of the entire set.
