M60 Powerpack change
A little investigativ question.
Does it matter on which side (right/left) the turret is for rising the power pack on an M60 Tank? I saw both on pictures.
And with a Magach 6b Gal Batash, as you have to remove part of the turret extra armour, is there a prefert side? I want to build a dio, showing something like that
Rabbits
Adding tot that; anyone got images of such a change and the enginebay opened up?
To RonW: a few pictures of engine removal from Magach 7.
Thank you!
I have a resin engine + bay that I want to use in a regular M60.
On an M60 (orA1/A3) the gun could be forward. There was a big enough space, where the driver could get into his position. On the hull, facing into the turret, was a panel with bolts that would be removed.The airduct to the generator was bolted to the hull, and would have to be removed. Then there was the throttle connection, And the tachometer connection, and fuel lines.
Now, if it was an early time period, with the AVDS 1790-A, there were 2 cannon plugs to be disconnected from the front lower part on the engine.
If it was a replacement 1790-c or D, those electrical plugs went up to the top of the engine and were easier to remove. Oh then the turret would be traversed to the side to remove the back deck
I think you can pull out the engine with the gun forward, because it is slipped in, why, you want to work squeased in, I am not sure… But for removing the engine deck, you have to turn the turret…
To pull the deck or the engine, the turret must be to the side. Either side will work, but it is usually pointed to the left, if possible, to make it easier to reach the disconnects that @TankCarlN3w mentions.
