Incidentally I bought my M88 kit when there a number on eBay. When I looked now I noticed a lack of the original version. Are they such a hot seller?
A good single blade nipper like the Godhand SPN-120 will cut these off cleanly with no breakage.
Looking back at the blog I wrote on Track-Link, that’s exactly what I did. I did cut between each attachment, but not all at once. I held the part in some flat/wide tweezers directly behind each nub for filing. Clamping in a PE bending tool is a good idea, so long as you can get a good grip behind each nub. If the part can bend away from the filing It can break.
KL
Do you happen to know what the road wheels on the M103 and M48 are called? They are the same, aren’t they?
They are called DISK: wheel, w/TIRE (vulcanized); they were P/N 7013976 on both tanks
KL.
I’m sure they were called all sorts of other fine Anglo-Saxon terms, especially when crews had to change them in cold, rainy, muddy conditions!
thanks
