I messed up my machine guns on my Meng merkava Mk4. Are there any 3d printed replacements or other stuff?
I am no expert so there may be model differences… In any case, for the FN Mag you can check
and for the M2HB
Which specific kit and what time frame?
For the Meng “Merkava Mk.4/4LIC w/Nochri-Kal Mine Roller System” 2010-2020
Are there any usable parts left? Most importantly the solenoids and remote firing system for the .50 cal?
If not your best option/choice is:
For the commander’s FN Mag, provided you have part D41 :
For the .50 cal you have the following options/choices:
Do not intall a .50 cal, since you are building an early MkIV (no loader’s hatch)
If you have installed the Droid you need a .50 cal so depending on what parts you have available you can get any aftermarket offering.
If you need a mount you have to build one or source a Legend productions LF1128 resin set
Take in mind that the Legend resin set is way more difficult to assemble than the Meng equivalent plastic assembly.
Thanks!
