Decalling underway - so far so good ![]()
The camo decals are on. Very thin and very strong. I have not used any decal setting agent yet. Does anybody know what setting solution works best?
More to follow ![]()
Tried Humbrol parts 1 and 2 but was not satisfied. Went to MicroSol and MicroSet and never looked back.
If you still have the decal sheet, use some spares to test your potion of choice and see if it works without a bad reaction. Just remember not to add too many coats at once and don’t play with it until it has dried and set…
Same here. I have MicroSol and MicroSet that date back decades and these solutions don’t go bad. They’re the only decal solutions that I use and clean up with water.
Another upvote for Micro Sol/Set. And if decals are extra-stubborn I have a reserve bottle of Solvaset…
Thanks for the feedback, guys. I actually also have microsol/set somewhere in my stash. I will try those out.
I can second other replies - in my case I use MicroSol & Set, sometimes supported by Mr Mark Setter/Softer Neo, but setter tends to leave some marks on surface.
Decals looking great, Jesper! Now I’m looking forward to do mine…after I read your opinion about them.
You did a fine paint job, too!
Peter ![]()
Oh! Nice to see someone else use Faller expert. I love that stuff. I mostly use it on bits where slow setting is fine, or perhaps preferred, such as two halves of a fuselage or upper and lower wings. Tell me how you use it, please?
Hi Phil, I use it just like you, in places where is need for a little more glue and good contact surfaces. For parts like bomb and droptank halves I prefer Tamiya’s liquid and thin stuff. But is was pure incidently that I bought it, because nothing else was available. I think Revell or UHUplast is still the same formula (simply must weld the plastic together…)
Peter ![]()
Not familiar with faller, but Revells glue is super for me. ![]()
Looking good, Peter!
Looking fantastic Peter.
Yes, thanks to the decals. They were pretty good to handle, not too thick, not too thin. But for safety I cut the big one for the middle fuselage in three parts. Now I’ll deal with the small parts for the landing gear and the ordnance.
Greetings
Peter ![]()
My hat is in the ring. Ordered ICMs Fiat CR.42 italian night fighter kit in 1:32, together with some Eduard PE (cockpit, seatbelts) and Eduard masks.
Pics to follow when the kit has arrived.
Regards
- dutik
Jesper, what Callsign will or did you use for your model? So we are building the same kit, at least I should use other figures… ![]()
