Meng Model 1:35 - Interior Set for M3A3 Bradley w/ Busk II
Hi everybody!
Is the Meng Model 1:35 - Interior Set for M3A3 Bradley w/ Busk II compatible for use in the Kinetic 61014 1/35 M3A3 Bradley CFV?
Thaks
Yes, I talked about it when I reviewed the original Orochi M3A3, which the Kinetic one started as.
https://archive.armorama.com/review/11172/
You should be able to fit it into just about any M2/M3 kit, but it may take a little work. I fit it into a Tamiya M2A2 kit with just a little sanding and fitting.
Yup, with a little sanding on the sides of the floor, it fits into the Tamiya and Academy hulls just fine as well. The turret fits into them too.
https://cs.finescale.com/fsm/modeling_subjects/f/3/t/182687.aspx
Thank you my friend!
Thank you very much!
Thanks for the advise!
I was about to ask…Kinetic made a Bradley? Then I remember Orochi…
Kinetic did add a new sprue of improved parts and new T161 track. The new parts fix most of the issues that the original Orochi kit had. It is quite a bit better.
I have the Orochi one with the metal tracks, think there was a resin figure in it as well
