So, taking advantage of the easiness of adding photos and posting for my mobile, here you have my work so far on Meng’s T-90 with Miniart KMT-7 mine sweeper.
MiniArt KMT-7 is a kit by itself, probably it has more parts than some Italeri models… Fit is fine, no big troubles.
However adapting it to Meng’s kit took some work, the upper hull attachments were easy and straightforward to add, but the lower ones were a pain. Maybe it was my fault because I should have not fit the tank´s dozer blade until the mine sweeper was in place.
The two control rods from deck to the lower attachment did not fit well either, had to be bent.
Other than that, it was a nice model.
And Meng’s kit is a joy, excellent details and fit.
