Ok, so Christmas PRessie time - son had a list of kits I liked and, in his wisdom, chose this one… Started the build and it is up to Miniarts small part, complex, fun quality. Engine went together nicely, chassis made up of a number of parts but seems to be aligned nicely… Each wheel is made up of 8 parts (7 parts of tyre and a wheel hub) and there are 7 of them to do so that will take a while… Going with the box scheme of 4BO and brown. Need to work out which components can be painted when and if I will display the engine or not…
engine just rested in - doesn’t seem to be a big unit
Looking good so far. I built this kit when it first came out, and as I recall there were no issues with the kit parts or fit, so it should be smooth sailing.
More work on the chassis… just some smaller parts to add (like 3mm by .5mm rod!!!) then it can be primed - chassis was all black which makes life easier. Next off will be the 7 wheels (done one)…
progress… wheels done, chassis done, now on to cab sub assemblies… a lot of this needs to be painted black so aiming to get all that built up first…
Looks good. I have to wheel set for part of the Miniart campaign. Looked easy, did you have any trouble with them?
not really… parts fit well and look the part…
cab assembly “done” (need to add glass, upper part of windshield, dashboard and build doors. Started on the truck bed (just to get some bigger parts done) - all sits nice & square after a bit of a battle with the front mudguards… at the moment all cab parts & truck bed are loose for ease of painting - hope to be able to start painting (well doing a black chassis) this weekend
moving forward… some fiddly bits but so far parts go where they are supposed to. Chassis painted black primer then a light coat of dunkelgrau to give it a bit of definition, green in the cab is MiG 4BO… bit of dark tracks for the rust… this is building up really nicely I must say - may have to look at some of the other AA/AAA kits (some of the anti-air or the refueler for example)
moving on a-pace with this.Cab on, half the bonnet on, elevating mechanism on, started on the 6 rockets and crates… I think a couple of weeks and this will be done & dusted…
I am liking how the build is progressing, keep it up.
Looking great here’s how mine turned out.
cheers Arty - Thats the TRACK-LINK build I believe… following that to pick up tips & tricks - great guide so thank you
yes it is. You’re welcome glad it was helpful.
build 90% complete, just need to add the lights on the front and rear and then the wiper unit to the windshield frame… priming at the weekend I hope
I bought that same kit the otherday, and looking at your build tells me it’s a great kit
gary
there are some thin fragile parts but it builds well - just take your time… I can recommend Arty’s build we discussed a couple of post ago - he highlighted a few issues/ build logic choices… URL is
primered… 4BO tomorrow, waiting on 6K brown to arrive so that is likely to be next week
camo done… not a huge variation green/brown BUT mt first freehand that has been semi-successful… you never know I may get this airburshing lark in to some semblance of good (brown was thinned with Galeria gloss which worked quite well)
wheels on (3 touch the floor), rockets and crates on… need to add front windscreen, attach bonnet open and then do a touch of dusting and a matt coat…
