Mirror models Morris C8 Quad
I was given this partially built Morris from Mirror Models and it comes with TPK resin wheels.
It is a subject I am wholly unfamiliar with, so there will be a learningcurve here. Any and all info regarding this vehicle will be most welcome! Maybe some far away and lesser know conflict, country of use (I am thinking Dutch Expeditionary Force in Indonesia post WW2) or colours/patterns.
I have been contemplating on how to do this vehicle, spending the better part of yesterday looking for information and references.
Apparently it was not used by the Dutch postwar army at all, so no KNIL/Indonesia. It neither is a sexy or versatile vehicle, only used as a tractor, really. So nothing exciting there either.
That leaves me with theatre of operation and related colours or camouflage schemes. But I do not want more olivdrab/green!
Hmm, what about a “Mickey Mouse”-pattern, like in Italy or Normandy?
Or perhaps Africa in light stone, pale cream or deep cream? Perhaps with dark green disruptive pattern or a national airrecognition marking? I like that one! Look at the different shades of “pale”.
Caunterscheme? Allthough that is already spoken for for the M3 Stuart…
Khaki brown with horizontal or verticle bands of black or green?
I went with the Mickey Mouse pattern when I built the Tamiya kit back in the late 70s.
But I also really like the 3-tone pattern (buff/light grey/light blue) often seen on the Matilda in WW2 - anything to perk up the subject.
@Abstractspoon I am leaning toward a combination of pictures 3 and 4, probably not historically accurate, but a plausible representation that makes this otherwise bland vehicle pop out more.
I went over what was in the box and most of it appears to have been assembled correctly and tidy. There is some scratch work done and a decent amount of PE, which is good, since I no longer have to do that.
However…. the roofhatch was glued shut and I wanted it open, so set about to carefully cutting and prying it loose. I also went over the remaining construction steps and noticed some parts were indeed missing, such as the presumed batterie next to the driver and 4(!) seats! So I have to try and make these myself… Luckily there are 6 in total and the parts for the other 2 are still there, so I will use those as templates.
It will be much easier to mask on this one, though.
Do you mean the pattern with the straight lines? That consisted of Portland Stone (a pale tan), Silver Grey (a light grey-green) and either Slate (a darkish grey) or “New Service Colour” which was Khaki Green No. 3 (a slightly greenish, dark brown). Light Stone (a pale yellow) could also be used instead of Portland Stone.
Very definitely, none of those colours is blue :slight_smile: That Silver Grey was light blue is a misconception from (at a guess) the 1960s–’70s that still keeps cropping up to this day.
Some great schemes there, and great diorama ideas as well!
An afternoon of tinkering with evergreen, putty and steel wire and I have the 4 missing seats!
Where there was nothing, now there is someting and I am pleased with it.
One kit chair assembled, one kit chair in parts and the roughly outlined templates, since it is easier to sand down then to add onto.
The results:
And in place
Happy to be corrected. Perhaps the silver grey only looked blue against the other colours
I suspect it’s a misinterpretation based on the name. I certainly wouldn’t expect a colour described as “silver” to be pale green.
The struggle continues.
Unfortunatly quite a number of parts are missing, so have to be homemade. Other… do not fit. The spare wheel from SKP Models does not fit within the frame, so can not be used. Mirror Models does not provide anything to attach the wheel to, anyway Checking references it was not uncommon to see the wheel or the frame missing in the field. I decided to keep the frame, add 2 beams and fill up the empty space with stowage.
Some old shellboxes (Italeri, I think), a few flimsies, some liberated jerrycans, a box and a tarp. Always does the trick.
I added steeringwheel and made a battery out of one of the kit’s flimsies, brought to correct size with evergreen. Added the PE tiedown.
I had clicked the body into place in order to be able to fit a number of parts in the right place. Now I can not get it off anymore. That’ll be fun when painting. I blaem inexperience with this sort of kit for this mishap!
I also started playing with soldiers… I had to alter the positions of knees, wrists and ankles to make them fit. The commander is leaning too much, so I could not place him on the roof. Now he stabilizes his binos by leaning the elbows on the frame. The scout is sitting on a temporary camouflagenet to get the right posture.
More PE
And I had to cheat a bit in order to get the wheels to sit reasonably level. The suspension was not leveled out properly.
Great work, Ron! Just a tiny inaccuracy: Jerrycan spouts always sat to the left of he central crimp seam (as seen when pouring), in the middle of the left can half. Looks like you might move the one on the can next to the flimsies.
Thanks! I’ll see what I can do to fix it.
Lots of great work here Ron! Looking amazing!
US style gas/petrol can
German style petrol/gas can
I get the impression that the nearest can is the German style
and the one closest to the flimsies is the US style
Many kits and some jerry can sets included both types and sometimes
the US/UK copies of the German can (which was better …)
There was also this “hybrid”, German style cap & spout (MUCH easier to open and use)
mounted on US style can.
The German can had two main parts, left half and right half, stamped and welded.
The US can had three main parts, stamped bottom, stamped top, main body made from sheet metal, stamped on the sides and rolled up to make a rectangular “tube” welded
down the back.
The German can had one weld that ran all around the middle, the US can had three welds, bottom, back and top.
“Easy” errrmmm, to open, and, most importantly, “easy” to close when stressed in the dark, getting the threads to line up.
Pouring technique:
Hold the can on its side, spout upwards, pour a little more than half the volume.
Stop pouring, flip can so it is on its other side, spout is now on the lower half.
Pour the rest of the contents.
The can is a lot easier to hold on its side since the handles are horizontal (hand does not slip) and the top corner does not hit the side of the vehicle.
It is surprisingly a lot of fun and it is cute of ugliness!
I ran out of parts, so this is as far as it’ll go, buildingwise. I suspect that an entire sheet of PE is missing, since I can not find the parts for the flimsy holders and rear mudguards. Not all that much of an issue, since these drove around without too, but it would have been fun to add them.
I added the brandlogo to the front, allthough it should not be there. Thought it was a nice detail.
Tried to remedy the spoutopening on the jerrycan, but it is cast in place and hard to remove without causing damage. And I have no spares at the moment.
The US style can is just fine as it is.
The German style can is good enough, maybe the spout should be half a mm
closer to the side but it is hardly noticeable.
Not even welds, they were seamed, to the best of my knowledge.
As per Jakko’s suggestion I will go for a Caunter paintscheme on this one. It will be a lot easier then what I had planned for the Stuart with all its nooks and crannies.
I’ll be using this set:
So I have begun to pait the Morris.
As said I used the AK-set; portland stone as a base inside and out, second layer is silver grey and last layer is slate grey. The paint is too thick to be used as-is and has to be thinned. I used a rough ration of 3:1 paint to water. This worked quite ok and the paint was thick enough to not bleed to much under the masking tape.
I used to colour images as a rough guide and used artistic freedom on the rear and top.
Compared to the Stuart that got light stone over OD
