Royal Model continues to release accessory items in 1/16 scale.
This is partial text from the full article (usually with photos) at https://armorama.com/news/more-1-16-scale-hands-helmets-from-royal-model
I’d buy a set of helmets like these in 35th.
What’s with the rivets on each side of the helmet? The M1 helmet never had rivets on the sides. Yes they’re easy to remove on the helmet without the net. But it’ll be tricky on the helmet with the net.
Back to the drawing board Royal model !
Correct.
looks like a Bundeswehr helmet shell from the 1950s / 1980s (M1971 Airborne Helmet ? )
Good spot, Maarten. I knew it looked a bit German.
Such a basic mistake.
I’m guessing they had a Bundeswehr helmet as a reference. But the liner is correct for WW2. The Bundeswehr used a liner similar to the WW2 stahlhelm.
I could also be really pedantic and point out that the brackets (bales) where the straps are attached are late war swivel bales as opposed to fixed which were manufactured up until late 1943.
But I won’t because the rivet thing is bad enough.![]()
Designed by someone with no knowledge of what he is making ,.
and your correct about the rest to ![]()
Not trying to sabotage or highjack this thread but someone asked about the US WWII M1 Helmet with mesh cover and suspension in 1/35th
Mikeybugs just completed these and is selling them out of his online store and they are BEAUTIFUL!
The Pattern: (that he scanned)
And the Finished Product in 1/35th:
Sorry Royal Models but the suspension in this 1/35th scale offering is more delicate, and more correct than in your 1/16th offering.
In this large scale, it makes more sense and realism to use actual netting material, than a molded on effect. I use tulle fabric on 1/35 helmets, which are much smaller, and it looks great.
I ordered a set of these before seeing this review. The good news is that they look great in person, and removing the rivets, even on the version with the net, is pretty easy to do. There’s enough of an impression of the net remaining that it looks fine. It’s also fairly easy (with a new blade) to modify the bales and straps to better resemble a fixed-bale helmet. The bad news is that these seem WAY too big for 1/16 scale. I have quite a few 1/16 figures, and the M1 helmet sizes are pretty consistent. These are quite noticeably bigger, maybe more like 1/12 or even 1/10 scale. Essentially they’re unusable in a 1/16 project.
