Motorcycle I.D help needed please
Hi Gents,
Please see below photo, I was hoping someone with knowledge on motorcycles would please be able to help with identificating the base model motorcycle this mad max trike was built on.
With my limited knowledge and availability of 1/35th scale kits I had purchased a miniart WLA to try and use. But then thought about some of the Zevesda 1/35th scale bikes.
Any help would be very greatly appreciated and greatfully recieved.
Thank you for your time, consideration and help.
Mike
I have seen many Chinese bikes, and that is almost certainly one, judging by the front wheel and motor alone. Tank is unfamiliar to me.
That looks like a Enfield to me made in India
I own a Royal Enfield, but with spoked wheels. Looking in garage now…
Very nice guess, but cylinder on that contraption is angled - at least for the 500 thumper (single) it’s vertical.
The Chinese base these little bikes on old CG series Hondas.
Hi Robert,
Many thanks for the reply and the enfield photo she looks great!! As a colonial I must admit I am more partial to old brit bikes, than american ones, although anything Indian until 1945 floats my boat and Harleys up until about 1930.
My original thought was to try and use the WLA, leave off one cylinder, but still couldn’t find a front well to match/suit.
Mike
Hi Oliver,
Many thanks for the reply, and definitly food for thought!!
Mike
Best best is to find an old thumper with the old school tank. You could always use a Ural - I found a railway maintenance rig on the Syrian border based on a Ural, so they were in use in that area.
Maybe not the same motor, but you’re going more for the effect I’m guessing.
This works:
Bronco Models (Kit CB35035)
The tank looks the part, and it’s a single cylinder.
Hi Robert,
Your correct re going for the look, but was also hoping to try and be as accuarte as possible and availbility of said kits/parts.
I will check out what Zevesda offer as well.
Many thanks for the help, tips and photos. It is greatly appreciated.
Mike
Replace the spoked front wheel with an appropriate sized aircraft wheel (or make one with the holes) and you’re there. Even the seat is correct - just add more padding with Milliput. :slight_smile:
Hey Robert,
Thank you so so much, what you call a Thumper, my cousin and mates we used to call them Tridumps…as in they always dumped oil :thinking::thinking::shushing_face::face_with_hand_over_mouth::zany_face::zany_face:.
And for all the Trumpy owners and riders out there, the thoughts we had on Trumpy’s never included the 500cc Bonnieville. :grin:
But that Bronco kit would certainly do it by the look of it.
Thank you so much
Mike
Triumphs have definitely evolved. Mine is an exact replica down to the Kevlar grips, or the one the won the Daytona 200 a decade ago.
Now she looks very nice and tasty, and rather quick to. If you are into your V twins, you may or may not have heard of a guy called John Britten from back home, a great story and doco to watch if you haven’t heard of him.
And my cousin back home who is into his bikes, new and old like yourself agreed with it bring a chinese bike of some make. So I am thinking I will get the Bronco kit and try and smash and bash something together from that and the WLA.
Mike
I actually started to build a Britten suspension on a CB500T - still have hopes to. I have the bell crank and the front shock. It was a cool setup. The thing was outlawed being it didn’t meat production number requirements, but in actuality no one wanted to race against it.
My first build:
Good plan, Mike. I’d treat the Bronco as the core and use the WLA mainly for the trike rear axle, luggage and small fittings. Before cutting, compare wheel diameters, fork length and engine width against the photo; if the Bronco wheels look noticeably out of scale, keep the WLA rear wheels and adjust the frame rather than forcing both sets together. A quick card mock-up of the rear axle width will save a lot of filling later.
Hi Robert,
Yeah John Britten ended up only building I think it was 10 before he died, all built by hand at that point obviously. His original plan from memory was to enter superbikes first after getting it into proper production, and then his real goal/dream was a 500cc motor gp bike. I still remember the footage of it at Daytona I think it was nailing and passing the factory Duc’s, Buels and everything else.
That looks like a nice bike already and those Britten shocks do look great, so I can understand why you would want to make one.
Mike
Thanks for the vote of confidence Ethan, yeah I think I will use the WLA tank on it, Trumpy motor and frame etc. I already have the rear wheels, and after what Robert said, I might try scratching it.
Mike
The Britten suspension will someday go on this CB500T, which used to look like the one behind it, before the carbon fiber and titanium treatment:
I probably would have finished it by now but I was dead set on having a two into one feeding into that titanium can, but the crossover pipe from the left cylinder would interfere with the linkage between the front shock/bellcrank assembly and the swingarm.
I sure do love the lines on it though.
Hi Robert,
A beautiful job of turning her into a vintage looking CAFE racer, and I can see that the Britten style suspension would look fantastic on it. And the pipes look awesome going into a 2n1.
My cousin did something similar, god nearly 35 yrs ago now on an old Norton 850 Commando, with 2n1 pipes as well, they just look mean and sound out of this world. He even went amateur BEARS racing which was obviously all vintage, British, European and American bikes, so seeing your beautiful looking racer brings back great memories.
Thanks for sharing!!
Mike
I’ve been looking this over again. Instead of routing the left pipe underneath the bike where it would interfere with the rod connecting the swingarm to the front bell crank, I could run it behind the downtube. It would take away from the aesthetic of the left pipe, but it could work.
