I ordered the KV-1 conversion kit directly from MR Modellbau. As soon as it arrives, I can tell you more about it.
This gives you the opportunity to convert the Tamiya kit to a rare variant produced at LKZ (Leningrad Kirovsky Zavod) in September 1941. The unique feature is a very early variant of the so-called simplified welded turret, which lacked interlocked joints and therefore had a reinforcing fillet under the bustle. As there was a lack of 120mm turret front plates, 50mm appliqué armour plates were added to the 75mm front plates as an interim stop-gap solution. The turret bustle is a shorter variant, therefore the rear-facing episcopes are closer to the rear wall, thereby eliminating a blind spot.
The kit also contains rubber-rimmed return rollers and a drive sprocket cover with 8 bolts, replacing the all-steel return rollers and covers with 16 bolts from the kit, respectively. Also contained are the appliqué armour plates on the upper hull sides and a short bar protecting the driver’s hatch, but the latter was not present on all vehicles.
