I have noticed a problem with my posts recently.
When I press reply in order to respond to another forum member this does not show as such.
For example, I pressed the reply button to this post by Johnny but it does not show as such, whilst his does
same here
Or is it because it is my post I do not see the reply mark?
I have had the same thing happen to me as well…
Ironically, it just happened with my post above … I replied directly to your post using the reply arrow lol …
Strange. I replied to the 1st post also. @staff_Jim a new feature with patch update?
Recently I’ve noticed similar behaviour if I highlight some text and choose “quote” - my text appears but what I quoted does not. Hadn’t been bothered to raise an issue yet, but maybe I should have…
Where’s that can of worms …
I only reply to myself. So is that like talking to myself?
—mike
You only need to worry if the answers are something you didn’t expect…
We only reply to other multiple personalities
(So clearly the system just worked OK for…Us)
No idea. I would have to read through a lot of patch notes to find out.
And… it shows that I replied to you so it seems to be working for me on this post anyway.
I did a simple test. It won’t show the reply element if you are replying to a thread directly above your comment. If there are comments between then it will.
