My weapons designs
Winchester 1873 24inch barrel is ready :slight_smile:
Is that all you used, you didn’t prime or base coat?
Hi, no, I use it over the acrylic color for giving a final tone and satin look. I prime and paint first.
The short 20inch Winchester carbine. I hope will test print some in 1/24 tomorrow :slight_smile:
“Brown Bess” musket :slight_smile:
The Winchesters and Brown Bess printed well, only the ramrod of the musket I think should be thickened little bit :slight_smile:
Cheers!
I’m considering making them in bigger scale 1/16 or 1/12 as standalone weapons. I will add more ornaments on the Musket and the Winchester :slight_smile:
Bazooka is ready:
A FGM-148 Javelin, the front cap and the handle are separate pieces, I will do the missile also
Test print:
Bazooka print and Javelin missile:
Probably could be painted better :slight_smile: , a quick painting for presentation. I’m not sure about the color, I used Lifecolor FS34102 Dark green.
That looks great. :+1:
Bazooka painted:
Excellent stuff! Crisp and accurate.
Thanks!
Musket painted :slight_smile:
do you have the .STL files for sale anywhere?
Not for now :slight_smile:
very nicely done.
How about try your hand at a PKP “Pecheneg” LMG?
Spetsnaz Model. Fitted with what i can assume is an Elcan SpectreDR on a Zenitco mount.
Standard model
