Night Pirate
More queries about the F4U-2. The outer starboard .50 cal was removed to compensate for the weight of the AI radar . The muzzle hole was faired over (flush ? ) but was the shell ejection cut out sealed up too? Photos I’ve found are “inconclusive” . I seem to remember reading that the window in the belly was painted over during the conversion. Yes? No? Maybe? I cant relocate the reference. Also, read somewhere that the radar pod fairing was squared off, not tapered like the one in the Tamiya kit. Anybody have photos of this. (Again, what I’m finding is not helpful.)
Oh! Did the -2s ever carry the centerline fuel tank?
All great questions. Hopefully someone knows the answers.
Me too…
Curious to know this,myself.
Welcome aboard Dave.
If you are working on a -2 here are a couple references for you. If you are using the Tamiya kit, couple pointers.(1) Their paining info shows the Oct. 41 - Jan. 43 camo. They were modified from -1s by Naval Aircraft Factory in early/mid 43 so would have been repainted 3 tone, “Norfolk” scheme. (I found the reference; the belly window WAS painted over.) (2) Tamiya says to use the flat canopy. (#D-2) but every photo of -2s I’ve seen show the one with the bulge (D-3) for the rearview mirror. Tailhook Topics Drafts: F4U-2 Color Scheme Tailhook Topics Drafts: F4U-2 Antennas and Other Stuff Another bit of useful info… " Vought F4U Corsair:
Sorting out the interior colours of the Corsair is particularly tricky. For the F4U-1 Birdcage Corsairs, photos taken at the time show the cockpits being a very dark colour, most probably black. Analysis of some crashed examples of F4U-1s indicates black, while the factory Erection & Maintenance Instructions called for Dull Dark Green.
As mentioned before, early production Corsairs had their interior surfaces in areas other than the cockpit covered with Salmon primer. This colour mixture was used relatively long into Corsair production. It would seem that all F4U-1s and a number of early F4U-1As were finished this way.
Somewhere during the production of F4U-1A model Vought discontinued the use of Salmon primers and switched to Zinc Chromate Yellow with cockpits in Interior Green.
In the engine cowling area, Vought adhered to the practice of painting its inner surface the same colour as the underside, ANA 602 Sky Gray on early F4U-1s, ANA 601 Insignia White on F4U-1As.
The wheel wells of early model Corsairs deserve closer inspection. Like the cowlings, the main wheel wells, undercarriage legs and boths ides of well covers were painted in the underside camouflage colour, ANA 602 Non-specular Sky Gray. Wheel hubs were silver. However, the smaller forward area of the wheel to which the leg itself retracted was left in the factory primer finish, Salmon. Some aircraft had also Salmon inner surfaces of the small covers attached to the undercarriage legs.
The canvas covers in the wells were probably drab -coloured.
With the advent of the tri-colour camouflage on F4U-1A the same principle was applied with white replacing the Sky Gray with ANA 601 Non-specular Insignia White, and the However, the undercarriage legs remained grey throughout the production of this model, possibly due to the failure or indifference to notify a subcontractor about changed colour specifications. For the record, some photos of -1As seem to show silver undercarriage legs, but it could not be established to what extent such finish was applied. One theory is that Aluminium lacquer was applied on these assemblies during field depot overhauls.
In October 1944 the new factory instructions for the F4U production called for application of Interior Green on all internal surfaces including the cockpit. As an anti-glare measure, all cockpit panels above the lower edge of the instrument panel were to be painted matt black. Curiously, the new directive did not explicitly state what was to happen with the cowling’s inner surface. Thus, subsequent machines showed either Zinc Chromate or Interior Green cowlings, until the last standardisation of colour post-war whereupon black was introduced in this area.
During that period, the wheel wells were also painted Interior Green. Undercarriage legs were initially still finished in light grey, but as existing stocks of parts were used up at the factory, the overall Glossy Sea Blue finish was carried over to the undercarriage legs and wheel hubs."
Thanks very much.
Thanks very much, glad to be here.
Any thoughts on the colors for the antenna farm on the U-2? Whip (blue) , radio altimeter (orange) , IFF (yellow). Kinda suspect the altimeter ones are black. Not sure on the other 2 . From what I know of such things they would not be painted. (ends o screw up broadcast/ receive ability.) I’m thinking “cream” fiberglass… (Gold star for anybody that can ID he map location in the background.)
Pretty much a SWAG. looks like the radar altimeter ones were black. Guessed the IFF was light grey. VHF… dark blue.
