I am in the process of building a military diorama in the Armorama forum and, as part of this, I’m scratch building a segment of a fictitious farmhouse, Normandy, France circa 1944, in 1/72nd-1/76th (approx. 00/H0), image below for interest,
My question is this, is anyone aware of any sets of early 20th Century farmyard equipment, e.g. spades, forks, milk churns, carts, etc that I could use to populate the yard area, it’s equipment only, not figures using it, .
Thanks for taking the time to respond to my post, that set looks like a possibility, and will go some way to a solution, and have use beyond just the farmyard, .
Thanks to Leo, Michael and Fred for both their kind feedback, it’s much appreciated chaps, .
Also a big thanks for the suggestions on equipment/implements/tools for use around the farm, I am definitely going to check out the Langley bits-and-bobs, thanks again, .
Although the following images are being posted in the relevant group build I thought I’d post a few as an update to anyone following this thread, .
Hi Fred, and thanks for the kind feedback, it’s much appreciated,
The camo netting is an open weave bandage (the white stuff in the image below) soaked in diluted white glue, and the ‘hessian’ strips are thin paper stuck to the bandage and then soaked in diluted white glue until it droops over the hull/turret.
I spent quite some time trying to find camo material, I’d read about open weave gauze bandage (the white stuff above) in an old modelling book, but found it difficult to source until I found some at a reasonable price on a well known online site named after a river. There might be better and more in scale options out there but works well enough for my basic skills in 1/72nd/76th.
The black stuff I use for 1/35th, as you can see it’s a slightly larger weave, again found on the same site being sold as a material for Halloween costumes, it came in a very large sheet for next to nothing…it’ll last me the rest of my model building lifetime for sure, .
The hay pile is a lump of DAS painted a dark yellow, in turn this is covered with yellow static grass, and then shadowed and highlighted with oil paints, the pitchfork/tools are from a cheap laser cut balsa set, they’re a bit ‘flat/2D’ but work fine at a quick glance, but I have sent off for the Langley stuff you suggested, to use where a more 3D feels is needed.
