I have more than 10 books with Panthers in and not one has a photo of the one above.
I have tried to find one online but no luck so far.
Takom/Das Werk have the scheme as an option but they have the gun cleaning rod container mounted on the side not the rear and the skirts have zimmerit as well.
In the picture above the cupola has no zimmerit either.
Can anyone enlighten me please? Or better yet have a photo of a late Ausf A from the same regiment?
The only photo I could find is from āGod, Honor, Fatherlandā a photo history of the Panzergrenidier Division of the āGrossdeutchlandā on the eastern front 1942-44
The caption reads-
āStanding in the cupola of his command Panther, Panzer regiment GD commander Oberst Willi Langkeit watches with amusement as Oberst Karl Lorenz of Pz.Gr.Rgt.GD chats with Leutnant Wentzke (in camouflage smock) and Hauptmann Gerbener outside Targul Frumos, May 1944ā
Hope this helps,
C.
Thank you.
Interesting photo. So it looks like I can forget Zimmerit on the skirts and it looks like the tube for the cleaning rod is not mounted on the rear.
So unless someone else comes up with a different photo it is 50/50 if Zimmerit is on the cupola.
That assumes of course that the picture is an Ausf A late?
Canāt help you there. Itās been years since I researched and built a Panther. I used to know the subtle differences but now I could only pick out a āDā āAā or āGā, not early or late. Hopefully someone adept in Panthers can chime in or provide you with a photo. Good luck.
C.
Here is another GD Panther A
The camo pattern on the profile looks more like those worn by Wiking SS PD, not Grossdeutchland.
Thanks for your help.
Zimmerit was never applied to cupolas. They were generally out of reach of an infantryman trying to apply a magnetic mine. This was largely a theoretical exerciseāthe biggest users of magnetic mines were the Germans themselves, so Zimmerit was basically a solution in search of a problem. When it was discontinued in September, 1944, nobody missed it.
It was only occasionally seen on skirt armor, since a magnetic mine on a skirt would probably do little damage to the main armor.
I canāt vouch for the accuracy of any of the identifications, but all of these tanks were purported by the websites they were posted on as belonging to the Pz Div GD:
As a side note - The first and last photos may be of the same tank, N1ā¦
Like Gerald said, I have never seen Zimm on a cupolaā¦
I have been looking hard for a photo of zimmerit on a cupola with no luck. Iād leave it alone.
Bill
@Catsrcool , my understanding is Zimmerit on Cupola is very rare on a Panther. It was done on occasion. I have no information on the specific tank youāre asking about.
@WilliamHarry William, please see below.
@geraldowens Gerald, on at least occasion Zimmerit was applied to Panther cupolas. I was also shocked to learn that.
For a Picture of a Panther A with Zimmerit on Cupola, Check Panther External Appearance & Design Changes by Roddy Macdougall & Martin Block on page 86
Part of Picture reposted for discussion purpose only.
Panther External Appearance & Design Changes by Roddy Macdougall & Martin Block is one of the most impressive references on Panther Iāve ever seen. It had many shocking bits of informationā¦like a picture of a Panther A command tank with the old Panther D Cupola on the new Panther A turret.
The book is incredible and if I could only buy one reference this year it would be Panther External Appearance & Design Changes. Itās well worth purchase price.
Assuming the tank is OEM and hasnāt had any parts swaps during maintenance, an A with no pistol ports on the turrets, a kugelblende, and sporting zimmerit would have started into production around the tail end of 1943. The other things I know that date a particular vehicle I canāt see in the photo the way the tank is posed.
So, yes, likely a Late.
Hereās your kitty;
Sorry for the low resolution, best I could do at the moment. Image is from Panzerkorps Grossdeutschland, page 132, Schiffer Publishing. The 200 is unambiguous in the original.
Looks like thatās the cleaning rod tube on the back.
While Zimmerit is uncommon on Panther cupolas, I was looking at one only yesterday which had it. From the pattern, it was a DB or MNH wagon, I think of SS-PR.12 in Normandie (I was looking at some images from that campaign last night).
I just found this thread. Iām not much of an armor guyā¦or havenāt been till likeā¦now. Iām looking for a good paint guide reference on Panther Ausf. A tanks. Iām going to try my hand at this and donāt want to just throw this thing together. Thanks for any help you guys can be
Hey Joe! I canāt offhand recommend any good reference books, but I will say that the Concord and Squadron āin actionā books on the Panther tank are not ones to get. I was disappointed in that respect on both books in regards to color scheme references.
Thanks for the heads up Carlos. Iāve seen one from RZM Imports entitled, āPanther and its Variantsā from Walter J. Spielberger that looked decent but havenāt read any real reviews as of yet.
