I am looking for one to do 1/48 WW2 planes. I have seen the Tamiya one but I would like to buy or make one that is cheaper than that one. How do you position your planes for painting and decaling? Thanks.
Thanks. My brain is on vacation.
I will have a look at that. I guess you are happy with it?
It’s okay for what it is- a 7.25 inch turn table made out of laser cut wood that rotates on a sealed bearing.
It’s also got a spring clip that clicks into each slot on the outer circumference. I thought it took too much effort to turn so I bent the spring down to make it easer to rotate.
BTW, I’m not smart enough to build aircraft. I use this as a paint stand for tanks and such. The reason it’s so clean is that there’s usually a piece of cardboard between it and what I’m painting.
As I understand it, the airplane holding stand attaches to this base.
Free. Just some foam glued together with a tail notch and a couple of cocktail sticks to stop it sliding off at an angle
