Panda M109A7
Carefully now: I am looking over M109 kits and yes, I have a Panda M109A7. Two things stood out:
  1. The lower hull of the AFV Club M109A6 (and Italeri M109 kits) is significantly shorter than the Panda M109A7 kit. I have not found any source saying it, but was the lower hull stretched or entirely new lower hull?
  2. What are the issues with the Panda kit? I have seen several posts about some things, but no one-stop-shop for the ills of the kit.
The lower hull is completely new. Initial prototypes were based on an altered A6 hull, and that’s where the problems began. The Panda kit was based on a prototype, and no one seemed to notice.
If you haven’t seen this, it’ll get you started.
Main deficiencies:
Duke box missing tone of detail - vents, hatch
Missing radiator filler hatch on engine deck
Underside is ficticious save for the two triangular portions
Rear hatch opening has the wrong shape
There should be no holes for the spade mounts (left over from original prototype)
Roof details wrong in many areas. Roof hatch on left is ficticious.
Missing semi-circular access cover on engone deck
Driver’s Enhanced Vision unit poorly detailed
That’s a start - not just a few misplaced bolts and misnumbered parts in the instructions.
Here’s a little more:
Thanks, I knew that there were problems but that explains it the way I needed to hear it.
Panda kit can be built as a fictitious 3-meter build…OOB and leave it at that. Pre-production, good enough.
Too bad I cannot use the lower hull/suspension as a guide for new tracks for the RFM kit. Trying t be cheap without having to buy the RFM kit. :wink:
The RFM upper hull is about 3 mm longer than the Panda upper hull. It shouldn’t make a huge difference. I’d make the lower run the correct distance for the Panda kit, and add an extra single link on each side just in case it’s necessary.
RFM on the right:
I forgot to mention, those tracks are spot on - about the only thing they got right. I haven’t assembled the RFM tracks, but the Panda tracks were actually easy to do, albeit time consuming. THAT is what RFM should have copied, not the mistakes.
