I am using Tamiya gloss clear over Tamiya spray paints and Tamiya panel line color.
I am having 2 issues.
1 is the panel line color is not running in the panel lines very well at all. I have shaken and stirred it very well.
2 is Tamiya x20 is not removing the dots of panel line color. What am I doing wrong?
Did the clear gloss fill in the grooves of the panel lines? If so the panel line color won’t have anywhere to go. If so you may have to rescribe the panel lines.
Tamiya Panel Liner is enamel based, X-20 is their acrylic thinner,does it remove enamel? Not sure.
