After the Panzer II and Panzer IV in Poland, I decided to finish off the Bronco Panzer IIIA kit
It has good fit and a nice interior for the turret but nothing for the hull. The decals were ok, but need setting solution to get them down over the hatches and vision blocks. I had to use MEK on a couple spots.
There were only ten of them built and they were withdrawn from service by February 1940. You can see the difference between the A and later type.
Have you built the Miniart early IIIs? If so, how did they compare to Bronco’s attempt? I found the Miniarts to be fiddly in the suspension and the plastic was very soft.
I used Tamiya acrylics mixed with lacquer thinner. The color of the tank has a blue tint, but real panzer grey is brown tinted. However, I don’t like that, so I go with the blue tints.
Thanks for the compliment on the Journal articles. I try to make them a bit humorous. At least mention my mistakes.
Nice work David , but did you notice the busted track RH front between drive sprocket and first roadwheel. Looking forward to pulling this out of stash at some point
I do use it as glue but found small dabs can take care of slivering and hard to set spots. Don’t brush it on like a setting solution, but just small dabs. Maybe practice first if you are concerned.
