Pre dreadnought battleship Mikasa of the Imperial Japanese Navy (IJN) 1:200
Tissue looks much better and has a hint of translucence like real flags have. I agree the ali foil is too unwilling to flow like cloth
That flag is perfectly ok for this scale
Hi Jörg,
excellent updates and progress, this is a real jewel you are building here! Calling it “museum quality” wouldn’t do it justice as many (most) museum models I’ve seen looked not even nearly as good as your Mikasa!
Your “tissue flag” turned out fantastic, too - that will be another great addition.
But - from what I can see, your flags seem to resemble Alpha, Juliet and Lima of today’s NATO alphabet…even though this goes somewhat farther back than only NATO time, I would assume the flags at this time, and in Japan, would have been different ones? I admit I have not checked it, it’s more like the flags you show look a little too familiar to me…
Fantastic work, and I truly enjoy following each of your updates!
Jan
Hi lads, first of all, a massive thank you for all your feedback!
I’ve been trying out a few things over the last few days and I’m absolutely delighted with the current result. The texture feels really good and the proportions are spot on now too.
Which brings me straight to Jan:
Thanks for the massive praise, mate! That goes down a treat.
By the way, you’re absolutely right in your assumption. Although the Imperial Japanese Navy’s system was based – then as now – on the visual patterns of the International Signal Book, the coding and meaning of the flags around 1900 differed fundamentally from today’s practice. To put it plainly: the purely visual design of the flags has been internationally standardised and unchanged since the late 19th century.
For my model of the Mikasa, this means: the flags looked exactly the same on the outside as those available today in model-making supplies. However, the crew on board at the time interpreted and understood them according to their own, traditionally Japanese logic.
And now comes the twist, where I’m deliberately deviating from historical accuracy:
For my model, this historical logic doesn’t matter this time. Why? Because I’m going to fly a signal from the masts that has absolutely nothing to do with seafaring! It will be a very personal message.
What is it? I’ll let you know in the next update – stay tuned! :wink:
A quick update from the rigging!
As I mentioned, I’ve now also run signal lines from the stengrah down to the flag rack.
I think the result looks great.
All that’s left to do now is to dye the ropes brown.
signal yard
or
signal yardarm
but since it is not attached to the outer end of yard carrying sails
I would call it a signal yard.
So now I’m really curious to see your very personal flag signal flying on the Mikasa! :smiley:
And thank you for that explanation concerning the flags - I knew they are much older than WWII, but I had no idea that they were going back to the late 19th century. That’s really interesting. Possibly they were built around the idea of having the maximum “optical distance” between every single flag? So you can discriminate them under bad conditions of when they are partly covered or not properly flying out. It makes perfect sense, once you’ve found such a system you wouldn’t change it.
Looking forward to your final pushes to commissioning!
Jan
Ahoy, you two!
Uncle Heavy, let me tell you: language barriers when it comes to translation can drive you absolutely mad sometimes.
For anyone wondering what all this actually means: in German shipbuilding terminology, the Stenge is the extension of the mast above the first Saling (the spreader or cross-trees, depending on the rig). Since the Rahe (yard) is mounted there, the correct German term is Stengenrah (topgallant yard). I got the terminology completely muddled in my last post – thanks for bearing with my jumble of words! I hope I’ve got the terms translated correctly this time.
I’m really looking forward to hearing what you think, Jan!
Look, here’s the Wiki page on the flag symbols. It’s genuinely fascinating: the system basically uses the international maritime signal flags and cleverly assigns different kana characters to the individual flags.
Sounds interesting, doesn’t it? Go take a look!
Yep.
A colleague helped me translate (before translators on the internet) a Russian ship model plan.
She got stuck on the Russian word for ‘schleuse’ (the ship was built with a hull adapted for going through the locks on Russian canals).
She used a Russian-English dictionary (she hadn’t been able to find a Russian - Schwedish dictionary).
The Russian word for schleuse was translated to the English lock (schleuse or schloss (aus locking a door)) and that was confusing. A ship made to pass through doorlocks???
Then I asked her if she had translated via English …
What would a ship be doing in a castle? Cruising around in the moat?
‘Stengenrah’ makes more sense than stengrah
:smiley:
Yes, I did actually forget the ‘E’ there, Uncle Heavy. :grinning_face_with_smiling_eyes:
A ship that fits through door locks – brilliant! :joy: That translation certainly made me laugh without meaning to.
But seriously: translators aren’t always perfect, especially when it comes to technical terms. Still, I’m glad they’re there! With my school-leaver’s English, I’d be out of my depth in English-speaking forums pretty quickly and would have to sit it out.
So: it’s great that these little helpers exist. They’re what make communication across language barriers possible in the first place. And if something a bit odd comes out of it now and then, at least we’ve got something to smile about. :wink:
Just completed a binge catch-up .. .. wow .. great progress and superb work Jorg … The mast and rigging along with the block and tackle set up is stunning … The signal flag looks perfect as well… Amazing attention to the smallest details… :ok_hand:
Checked the Wiki link - that’s really interesting, I was not at all aware of this! Now I have no idea about the kana characters…that would be something for the later mentioned translators, though I have no idea how I would explain my computer what I want to have translated :laughing: fascinating anyway!
Hi Johnny! :blush:
It’s great to have you back on board!
As you can see, I haven’t been idle in the meantime and have been hard at work. :wink: We’ve definitely missed you here – so it’s all the better that you’re back!
Hello everyone!
Today we’re moving on to a very special stage of the build, one I’ve been looking forward to for a long time.
Thanks to the active support of many users from the various forums I frequent, I’ve finally been able to work out exactly where the signal lines need to be attached. So they’re all in place now. I did, however, deliberately save one of the last lines for something special.
But more on that in a moment.
As you know, I’ve decided to make the signal flags out of tissue paper. I applied the colours with a brush, deliberately working a little more generously than the actual flag surface requires.
There’s a very simple reason for this. When you trim them later, it ensures you get a clean, evenly painted edge. This creates small but subtle details which, I hope, will make the desired impression in the end.
You can already see here which three signals I want to depict:
J (Juliet), L (Lima) and A (Alfa).
Before I reveal what I’m aiming to achieve with this unusual combination of signals, the little flags must, of course, first be strung up.
To do this, I threaded them onto a generously sized piece of rigging twine. I folded the ends over and sealed them with acrylic glue.
I then left the whole thing to dry undisturbed overnight. After all, I don’t want the folded-over ends to come undone when I shape the flags later on.
For the next step, the flags are thoroughly moistened once more with diluted acrylic glue. This makes the tissue paper nice and supple, allowing it to be shaped as desired. This way, I can give them the most natural-looking drape possible.
Once this work has dried thoroughly too, nothing stands in the way of hoisting my very own personal signal.
And that brings us to the question of what I’m trying to express with this signal combination, which, admittedly, is not exactly commonplace and not really maritime either.
This signal is a very personal tribute to my dear wife.
Translated, it means ‘Jörg Loves Andrea’. :smiling_face_with_three_hearts:
She gives me every freedom I could possibly wish for in my model-making room. She supports me in my work, follows each stage of the build with interest, and constantly encourages me to carry on with what I do here with such passion.
But there is an even more important reason for this small gesture.
During this model-building project, in 2024, we went through an incredibly difficult time together. My wife had to overcome a serious illness.
Whilst she was undergoing chemotherapy, I put my model-building on hold completely. I simply lacked the strength and the peace of mind to work on the model whilst my thoughts were elsewhere.
It was only once we’d left that terrible period behind us and my wife was back on the road to recovery that I returned to my model with renewed energy and even greater determination.
From that moment on, I was certain: I wouldn’t just finish this model. I wanted to dedicate it to my wife.
And that is precisely why we’re at this point today.
I am now pulling countless wafer-thin elastane threads from the frame down to my self-designed flag rack and securing them there. It’s quite a delicate task, one that requires a little patience and a light touch.
And if you look very closely at the bottom right, you can see me on the bridge ridge.
There I stand, hoisting these three little flags for my beloved.
To me, they are far more than just a few pieces of painted tissue paper. They symbolise gratitude, solidarity, love and the fact that even the most difficult times can be overcome together.
And perhaps that is precisely one of the most beautiful moments of this entire model-building project!
What a really great way to say thank you to SWMBO, brilliant idea and the flags will always tell that story :+1:
Bravo, Jörg and Andrea! :clap:
A huge thank you to both of you! :blush:
This has really been on my mind for a long time, and what can I say: my wife was absolutely delighted.
Well done Jörg, that is brilliant.
Good morning, dear craft community!
That’s so kind of you. Thank you very much. :hugs:
The rigging between the masts is now complete. I’ve fine-tuned the spacing and alignment of my signal flags once again.
I’ve attached a small black dot to each of the lines. This is meant to represent the shackle with which the individual flags are normally attached to the line.
The Marconi aerial is also stretched between the upper yards. The small white dot represents the corresponding insulator.
I then ran a guy rope for the aerial down via the pulleys and secured it to the outer deck using a small rope tensioner.
And so the initial tangle of threads is slowly taking shape. Bit by bit, the individual lines are turning into a proper rigging.
Next, I’ll carry on working on the boat’s deck. A few figures still need to be positioned there, and the railing is also waiting to be fitted.
I might even manage to fit the davits for the cutters. I could probably remove the black protective covering from my assembly stand afterwards, as I won’t need to do anything more to the centre of the model.
You know my motto: always work from the inside out!
So the work continues, and slowly, all the little details are coming together to form an increasingly harmonious whole.
I’ve run out of words… its all the tiny details you have added that make this a work of art.
The flags could hardly have turned out better if nano-tailors had run them up for you.
Keith
