I got a decal set, but the ones for the Char B1 Bis depict the flamethrower versions. Did the more conventional B1 tanks get sent to the Balkans as well? The division was given old and foreign equipment, and used against partisans rather than modern armies.
No idea on an answer to your question.
However, if you take the time to select a forum for your posts, they will be seen by a wider group and those who are interested more in the topic, hence getting a better answer. The Uncategorized forum isn’t seen by many.
I have moved this one to the Armor/AFV forum.
I think so, if you do some more googling I think you’ll find one.
I have some books at home about the division and I’ll give it a look later (don’t let me forget!)
Had a look thru my two PE books and could not find any non flamm versions.
