Yesterday I was going to paint the last part of the tracks of the Sd. Kfz. 9 Famo I’ve been working on for so very long now. But, the airbrush problems were back to bully me again. And that’s odd because the session before, everything did go pretty well. Previous session I decided to first test everything thoroughly before starting with my session. Testing was done by first spraying tap water through my airbrush, which didn’t have any problems. It seemed everything was working just fine. The second test was spraying some Tamiya acrylic thinner through my airbrush. And again, everything seemed to be working just fine. And last but not least I sprayed some Mr. Airbrush Cleaner through my airbrush which seemed to be working fine as well.
With the spraying of the Tamiya XF-56 I first did have some problems. With unregular spraying pattern. And I first thought, what if I crank up the pressure? But then I first decided to pull back more on the trigger. Open the paint more. And when I did that. It seemed to be spraying just fine. With of course maintaining a larger distance from the track. I did conclude I could have left the paint a little less open. Just a little. But, I was pretty satisfied with the result overall. I also recognized I made the mistake of wanting to do everything in one go. And that I should have done it in more layers. But it seemed the paint held up pretty well. Even when scratching the paint with my finger nails. Little ammounts of paint came of. Which gave me the impression that the paint was holding up pretty good still. Plus, I had primed the tracks beforehand with Revell Basic Color spray can primer. Which I’m also thinking I want to use up and then try some other primers as well. Spray can or airbrush. Particularly Mr. Hobby primer, because I have read good stories about that stuff.
The next session however, which was yesterday. Assuming would now just be working fine. It didn’t. I mixed up the paint for my airbrush in my Mr. Paint Tray cups. Putting 2 parts paint in, 4 parts thinner and one drop of Tamiya paint Retarder. Which was also the mix ratio I used previous session.
But, this time I had a serious problem. Huge bubbles splattered out of the paint cup. Luckily I did put in first a small amount of paint. Otherwise it would became a mess. But it obviously wasn’t very good. So, I poured the remaining paint out of the paint cup back in the Mr. Paint Tray. And decided to run some thinner through the airbrush. But, still bubbles. And a very unregular spray pattern. Just a sputtering and hissing sound and spray pattern. After that, which didn’t seem to work to solve the problem. I did run some Mr. Airbrush Cleaner through. I decided to first let everything bubble in the paint cup. Like the ‘backflush’ method with blocking the front of with a finger. Except, I didn’t block it of with my finger. I also don’t have a cap for that. And the air cap on the front of my airbrush has also wholes in the sides. Which makes it impossible to block it of with just a finger tip. When I did look in the paint cup. I noticed a lot of metal pigments floating in the Mr. Airbrush Cleaner.
So I did run the airbrush cleaner through my airbrush. And took everything apart. First the nozzle assembly with the aircap, and the other parts. Inspected it by keeping it in light. And everything seemed clean to me. So I did some Mr. Airbrush cleaner in a Mr. Paint tray and did let the nozzle soak in the airbrush cleaner for a few minutes. But nothing seemed to come out of the nozzle. I believe some paint could be on the cleaning brush I cleaned the nozzle with. But that could also be from a previous cleaning session I believe.
Then I pulled the needle out the front of the airbrush. In order to not pull all the dirt and stuff you don’t want in your airbrush through the airbrush body. And dropped it carefully in the Mr. Airbrush cleaner solution. Letting it soak in there for a few minutes. After that, taking it out of the Mr. Airbrush Cleaner and wipe it across a paper towel. Not much if any came on the paper towel in terms of paint or pigment. Even when getting some Mr. Airbrush Cleaner on the paper towel and giving it another wipe. It just looked very clean.
And then I cleaned the paint cup with the paper towel and Mr. Airbrush cleaner on it. Took a cotton swap and also did the area lower of the paint cup. Which did have some paint coming out on the cotton swap. Did this a couple of times until it looked fairly clean.
After that, I did do the exact same thing on the front side of the airbrush. Which also had paint coming of on the cotton swap. I did this also a couple of times. Until that looked fairly clean as well.
With my whole day being ruined. I just tidied everything up. Stored everything away on the place where it belongs. And still having no idea what has happened or did go wrong. As far as I know I did nothing wrong. Apart from not testing beforehand if everything was working properly.
What could be the issue? What should I do next time a problem such as this occurs? What would be good practices to prevent problems like this as much as possible in the future from happening?
