AUSA 2018 saw General Dynamics exhibit an AFV with a 50mm cannon, Switchblade loitering munitions, Iron Fist APS, & CROWS-LP. Since learning CAD, I’ve modelled & printed it.
Still interested… if you decide to make it available.
If you decide to sell it, I’ll buy one—thanks.
No plans to sell this atm. Just not set up for that.
Part of the refinement of the design was to separate the hull & turret into upper & lower halves. I also added some guide holes so that the gun & mantlet/gun shield can be set at 85°.
My friend, if you decide to go for it, all you need is a PayPal account and a box for shipping… let me know, thanks again.
This is just a prototype, and in that guise just dressed up for a show. The production version will likely be different, assuming Griffin is selected over Lynx. I wonder if the same Ajax flaws are showing up as Griffin is derived from the same evolved ASCOD platform
I wouldn’t even call it a prototype - it’s a concept demonstrator/trade show special. An optionally-crewed turret with a 50mm dual-feed gun (+85°/-10° elevation/depression), loitering munitions, radar/UV/laser-cued active protection, ECM, an RWS, & a commander’s independent viewer in 2018 was pretty radical a concept!
If you decide to sell me a kit, they will certainly be needed. ![]()
The hull is now done. The 3D hex camouflage on back of the hull roof was extended to improve coverage. The grey model is the final configuration.
Here’s the latest paint mule. Improvements to post processing plus changes to print orientation & resolution have sharpened things up considerably.
Not bad for 1/48.
